Any ideas on where to find grounding kits? No DIY
the second DIY thread i linked above already has all the measurements done for you.
if you can't make you own grounding kit, you probably have no business installing a pre-made one anyway.
Well, with the older Pioneer Headunits (not sure if its the same design, I'm talking 2007 design), if you disconnected the RCA without the unit being off, a pico fuse would blow. This would in turn cause horrible grounding issues. Resolved is to make a beefy ground, and ground it not to the factory ground, but to the chassis.
From that date on, that was enough proof for me that Lexus had grounding issues - but makes sense now to say all Japanese cars do as well. More or less.
When I did my grounding kit I took a before and after video and compared the time difference between when the gear number changed on the LCD screen and when the revs dipped. All the shifts were about .6 seconds although with the kit I had a fast .4 sec and a slow .8 sec shift. Even though I was skeptical about the grounding kit, it did "feel" better after installing. I'm going to have to take the kit off later this week so I can look again at shift times without the kit.
But still, if I put a big turbo on an engine and it will brake down, is it then a bad engine? More or less the same with the radio example, that the factory doesn't calculate the wiring being used for a HU with RCA cables is a way of engineering and not delivering a bad product.
If this is for audio purposes...why not just do a better grounding job on the audio install rather than getting a grounding kit for the engine bay? What am I missing here? I dont think the kit that goes in the bay has anything to do with the radio and how it will function
In car audio, we run BIG 3 (it may be big 5 now or something). Essentially grounding the battery to the engine, and chassis, and positive wire ran directly to alternator. How To Perform The Big 3 Upgrade | Learning Center | Sonic Electronix
A little overkill for this purpose though. I think 2/3 big 3 will suffice for audio. Wheelhouse
you may not have any issues. it can only help, though.
better, cleaner signals from all the electrical sensors is always a good thing. make some extra ground wires yourself for $20-$30 - dont waste money on a pre-made "kit".
i replaced ground straps and cleaned ground points all over my Porsche 928 ... what an electrical nightmare!
wow what a damn rip off. i know in the op the guy said he doesn't want to make his own but holy krap $132 for a couple of grounding wires. i rather save the money and make it myself.
agreed
