Does anyone have this front lip?
I found this on ebay. Has anyone installed this lip in the past. Any comments on quality, fitment, etc. Any additional pictures?
I have it. It was bent when it arrived from China. It straightens out with heat....It's Polyurethane I think. First put on one side at the wheel well.Put a couple of screws in to hold it. Meanwhile, use 3M tape, the good stuff from ONLINE NOT the Auto Store. Put the tape on the lip NOT the car.Leave a tail on each piece to pull the paper off the adhesive and then fasten the lip top the other wheel well . After tacking it on the wheel wells just pull the strips off by the tails you left ...press to the car and then fasten it securely at the wheel wells . The lip will take the shape of the car as it sits in the heat of the sun. Or use a Hair dryer. The most important thing is to buy 3M prep vials of liquid...they are in a breakable capsule with cotton applicator . That will prepare the surface after you have thoroughly cleaned it with cleaner/prep. Don't paint it. It would need Flex Paint and that is very expensive and I guarantee it will still chip. Just use that Rubber / plastic protector stuff and buff it up. It's better than a fiberglas lip because it will bend not crack on impact.
A bit OT but your grille looks great.
did you paint it youself?
Is that Plasti-dip or is it regular paint?
G-thirty7X
11-02-2015 12:41 PM
