tinting problem?
Old Jun 19, 2014 | 10:08 AM
ratedg37x's Avatar
ratedg37x
tinting problem?
So I just bought a 2011 g37x coupe. I eventually plan on tinting it. My dad has a 370z that he has had it tinted and has problems with the fact that the windows go down when the doors open, causing the tint to peel (because of the no opening the windows for 3 days rule). The g does this also, so am I going to face problems trying to have it tinted?
Old Jun 19, 2014 | 10:25 AM
DPNx714's Avatar
DPNx714
You shouldn't have any problems with the tint curing from the window moving slightly up and down from opening/closing the door. My friend and I both dropped off our cars the same day and both our tints came out perfect. He has a FRS with the frameless window as well.
Old Jun 19, 2014 | 02:55 PM
Dillybar12's Avatar
Dillybar12
You should have no problems with the tint. I recently had my 2010 G37 x tinted about a month ago, everything cured just fine. I went with 20% on my all the way around and have no complaints what so ever.
If anything would happen, most places offer warranties for their tint. Which is why I would recommend also getting it done professionally just incase something were to happen.
Good luck, be sure to post pictures when it's done!
Old Jun 19, 2014 | 03:48 PM
inyquest's Avatar
inyquest
Great post.
I was wondering the same thing. Though I have not heard of the 3 day rule.
I guess I should think about parking my car outside for 3 days after I get it tinted
Old Jun 19, 2014 | 04:00 PM
2008G-Man's Avatar
2008G-Man
A good installer will use a dryer on the edge ... millions of us tint with no problems.
Old Jun 19, 2014 | 07:08 PM
GW330's Avatar
GW330
You can unbolt and remove the sensors that detect when the door is open or closed. This will leave the window up all the time. I left mine removed a day or so until I felt comfortable that the tints were dry enough. The tint place should know this.
Old Jun 19, 2014 | 07:58 PM
PongSanity's Avatar
PongSanity
Put a dryer or a heat gun on it. .. you'll be fine... I know about the overnight rule. ... not three days. ...
Old Jun 19, 2014 | 08:23 PM
inyquest's Avatar
inyquest
Wait, what?
Where is this bolt and how do you do that?
Old Jun 19, 2014 | 08:56 PM
BeachmanQ60's Avatar
BeachmanQ60
Any good professional installer with slide the tint low enough below the window seal to avoid any chance of this happening.
Old Jun 19, 2014 | 09:22 PM
Scotty_R8's Avatar
Scotty_R8
all i did on mine was take a screw drive and turn the screw in the door jam that holds the "button" and turn it a quarter turn and my windows stayed up.
Old Jun 21, 2014 | 09:08 AM
inyquest's Avatar
inyquest
Can someone please post a pic of this screw and it's location
Old Jun 22, 2014 | 10:15 AM
sprix's Avatar
sprix
You really don't need to worry about the small movement of the windows after doing tint if the tint shop is in the vicinity of professional. I've never had problems related to this and I've had quite a few cars with frame-less windows that do the same small movement when opening and closing doors.
Old Jun 22, 2014 | 01:09 PM
GW330's Avatar
GW330
edit* heres an image of a 350z. But look at your door seam, theres a sensor that you push that detects if the door is open or not (like anyother car). Ill see if I can take a pic and post it.
Old Jun 23, 2014 | 09:05 PM
Джон's Avatar
Джон
the guy that tinted my windows removed the door panel so that the tint would go below the window sill edge
Old Jun 24, 2014 | 12:52 AM
kG37s's Avatar
kG37s
never had any problems with mine.. just dont mess with the windows for the first day
