Steering wheel trim swap
Old Apr 22, 2014 | 09:36 AM
ZachG37's Avatar
ZachG37
The trim piece on my steering wheel is all scratched up and i have another to replace it. Wondering if i absolutely HAVE to go to a dealer to get it done (because of the airbags) or if i can do it myself.
Old Apr 22, 2014 | 09:51 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Hello Zach, welcome to the forum. Lucky for you, this is a very established forum. There's a DIY for just about anything you want to do to your car. I found this DIY in the sticky section, you should take a look at what's available if you're curious about other mods.
https://www.myg37.com/forums/d-i-y-i...ement-diy.html
Old Apr 22, 2014 | 10:35 AM
OG2B's Avatar
OG2B
Thanks I needed this as well
Old Apr 28, 2014 | 09:16 PM
Skyfox16's Avatar
Skyfox16
If you attempt to do this yourself, make sure you have the correct torx bit. Mine were the "Security" torx screws not the regular ones so i had to go buy a set from harbor freight. I then asked my dealer about the trim and they ended up replacing it for free so it might be worth it to check with one.
Old Apr 29, 2014 | 08:15 AM
Carfanatic's Avatar
Carfanatic
Hey check with your dealer , some dealers are replacing it under warranty , if your warranty is over even by a year they'll do it just tell them that all the infiniti's have the same problem and for a premium vehicle its non-sense to have dash components rub off...
Welcome to the Forum !
Ryne
Jan 18, 2016 05:39 PM
joeposter
Sep 8, 2015 04:36 PM
xpcgamer
Sep 5, 2015 09:28 AM
mauiwowie
Aug 16, 2015 06:01 PM
