stillen gen 3 long tube intake vibrating probs
Old 08-12-2013, 07:41 PM
Jimmy1
Jimmy1's Avatar
I installed the long tube intake on my g coupe about a month ago and its been vibrating against my strut tower from the beginning. tried putting little pieces of rubber between them but it always falls off. tried to adjust the fitment and it always just comes back to vibrating. Anyone got any ideas for a permanent solution other than ripping it all out?
Old 08-12-2013, 08:03 PM
2013 g37s
2013 g37s's Avatar
I had the same problem,, we added a strip of that vibration dampening material ,, sticky back just peal it and stick it
Old 08-12-2013, 08:06 PM
Jimmy1
Jimmy1's Avatar
where can i get said material? and whats it called ?
Old 08-12-2013, 08:12 PM
2013 g37s
2013 g37s's Avatar
We picked it up at a car stereo shop,, don't know what its really called ,,, but I do know it worked
Old 08-12-2013, 09:15 PM
ANMVQ
ANMVQ's Avatar
I had a half peice of coolant hose on mine, but min was rubbing
inside the holes I cut in the rad support . But I bet this would work here also .
Old 08-13-2013, 11:18 PM
Zydan
Zydan's Avatar
Sure you can find a smaller size for cheaper, but this is what you're looking for.
http://www.ebay.com/itm/6-Trunk-Vibration-Dampening-Pads-12-X-12-X-060-/400533389689?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d41a68179&vxp=mtr
Old 08-14-2013, 11:52 AM
GTLAW
GTLAW's Avatar
Smile
Noy to sound like a jerk or anything, but not sure if you did the install or a shop installed them but they are not installed properly if anything is rubbing. I installed mine and I should post up my DIY.
I will post photos of the install that I did my self, install time was about 10 hours. Because I wanted to make sure it was done right. This was done on my old 2011 G37. I would never install STILLEN again on my car.
Here is the photos.
I used a space form to make sure no contact from pipe to car.
Old 08-14-2013, 02:49 PM
IN10SS
IN10SS's Avatar
Mine rubbed on our 08 coupe. Spent some time adjusting but it would end up in same place. Used a little rubber adhesive foot from a piece of furniture. Still rubbed where it went through Radiator support. Had severe heartburn cutting up the radiator support enough to be rub free. Now unit is in box. Don't want to install on our new S sedan.
Old 08-14-2013, 04:03 PM
Ph34r
Ph34r's Avatar
IN10SS, looking to get rid of it since it's just sitting in a box?
Old 08-15-2013, 03:16 PM
G Nepal
G Nepal's Avatar
6 Trunk Vibration Dampening Pads 12" x 12" x 060" | eBay
Come do mine.. since u seem to know what u talking about. Danny Boy! lol
Old 04-30-2014, 12:03 PM
d0m0
d0m0's Avatar
I'm having this problem right now
Old 04-30-2014, 02:34 PM
rmfnla
rmfnla's Avatar
Yeah, share the joy!
Old 04-30-2014, 03:01 PM
Vance67
Vance67's Avatar
I think the product is called dynamat technically? I could be wrong
Old 04-30-2014, 04:15 PM
G Nepal
G Nepal's Avatar
You are right. I just have rubber hose which is sitting tight. It's been almost a year.
Another way of doing it would be to get the biggest hose you can from Autozone and buy couple of clamps. I am sure you can figure out the rest.
Good luck.
Old 04-30-2014, 05:18 PM
Skyline6mt
Skyline6mt's Avatar
I used this wrap made of cork with a stiffer cardboard/rubber wrap and then black gorilla duck tape around the pipes for where it passes through the radiator support then used a similar soft black padding near the strut towers and have had no issues. Picked all of this up from auto zone. just make sure you dremmel off enough of the core support so the pipes can pass through freely and you have some wiggle room. Shouldn't have any problems.
Quick Reply: stillen gen 3 long tube intake vibrating probs
