Clutch chatter in 09, is anyone else experiencing this?
Old Aug 2, 2013 | 08:55 PM
toughcookie's Avatar
toughcookie
Hey guys,
I have a 09 Manual Sports package with about 38k on it. When the clutch is engaged and the car is revved (such as when starting the car or creeping up at a light) there is a loud rattle.
I have taken this into Infiniti twice already and have a meeting with the District Infiniti Engineer next week but basically they are telling me this sound is normal but there are only 30 complaints of this sound.
Through researching the forums I heard some people call it clutch chatter, ultimately im wondering if anyone else is experiencing this sound also? I know this is common with aftermarket clutches but im pretty sure mine is stock.
It's so annoying, i just upgraded from a 03 G35 that never sounded like this!
Old Aug 2, 2013 | 09:19 PM
12G37S's Avatar
12G37S
Originally Posted by toughcookie
Hey guys,
I have the same issue in my 2012 sedan it only has 3300 miles on it. I have an appointment later this week. Hopefully they don't tell me it's normal.
Old Aug 3, 2013 | 01:46 PM
toughcookie
I've talked to someone who had this issue in 370z, im scared this really might just be a normal sound. It sounds so bad
Let me know what your Infiniti says
Old Aug 3, 2013 | 01:52 PM
jjasonSU's Avatar
jjasonSU
They're transmission make a lot of noise.
Mine doesn't when I rev it, but once u sit and disengage the clutch u hear it. Also when I turn the car off, it rattles itself to sleep.
Old Aug 6, 2013 | 01:13 AM
BiH21's Avatar
BiH21
I had the same issue and dealer said something was not right with flywheel. They changed it under warranty.
Old Aug 6, 2013 | 12:08 PM
toughcookie
That fixed the problem completely?
Old Aug 6, 2013 | 01:00 PM
BiH21's Avatar
BiH21
yes, I had it fixed last week. I can not hear it anymore
Old Aug 9, 2013 | 09:02 PM
12G37S's Avatar
12G37S
Dealer checked it out and says its normal. I'll let it ride unless it gets worse.
Old Jan 11, 2014 | 08:53 PM
12G37S's Avatar
12G37S
Update
Dealer has replaced the clutch, pressure plate, throw out bearing and slave cylinder but the sound is still happening after warmup. Dealer and Infiniti USA are now replacing the transmission because they have diagnosed issue down to the input shaft bearing on the transmission. I should be getting my car back on Monday if the issue is resolved.
Old Jan 11, 2014 | 10:26 PM
canucklehead's Avatar
canucklehead
Uuhh, yeah. That is definitely not "normal". I'm sure the new gearbox will solve the internal problem for you. Plus, you already have a new clutch system. Sounds like you should be all set to go. Good for you to not settle for the old "normal" play that some dealers try.
Old Jan 12, 2014 | 12:50 PM
Racindaddy's Avatar
Racindaddy
I had the same issue. The dealer replaced my entire clutch under warranty. The noise was gone. For about a day. Then it started again. It rattles itself to sleep when you turn off the car. Annoying....
Old Jan 12, 2014 | 11:24 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Just shy of 12K in my 2012. I hear a slight rattle if I don't feed it enough throttle on take off. Nothing like in the video above. The marbles in a can like noise is normal on most MT's, especially with the clutch engaged in neutral.
Old Jan 17, 2014 | 03:27 AM
HeathG37s's Avatar
HeathG37s
Ya same hear my manual rattles just ever so slightly with no throttle but once I touch the throttle it goes away, I guess that's normal in these cars?
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
vamarris
Dec 9, 2018 11:10 AM
redlinernyc
Feb 29, 2016 11:06 PM
stevo4756
Oct 9, 2015 01:54 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
