Horrible morning
Old Feb 20, 2013 | 10:45 AM
Way2flyy's Avatar
Way2flyy
Horrible morning
Woke up this morning to drive my g, after a long vacation been wanting to drive it bad. I go to start and it doesn't start, all interior and dash lights came on but car didn't start up. Now I'm pissed off, I kno it's needed an oil change prolly like 1k miles ago, and has been sittin in the freezing cold NY streets. It's an 08 wit 69k. Before this recent time away from the car, always replaced filters and oil at 3k. Is there anything I can do to find out what's the problem before I pay a tow n mechanic all my money?
Way2flyy's Avatar
Way2flyy
Oo n I got a damn flat smfh. Jus not my day
Old Feb 20, 2013 | 10:58 AM
bmbweber's Avatar
bmbweber
does it even turn over when you try to start it?
Old Feb 20, 2013 | 10:59 AM
XMMAN's Avatar
XMMAN
does it try to start or just nothing when you hit the button?
Old Feb 20, 2013 | 11:02 AM
Rad_Slinger's Avatar
Rad_Slinger
Probably just the battery, especially if its been sitting for too long....get a jump.
Pump up the tire. May have a slow leak in one of them....and it's been sitting for a while.
Old Feb 20, 2013 | 11:11 AM
http://x.infinitihelp.com/forum/show...69.html?t=6769
Old Feb 20, 2013 | 11:12 AM
Way2flyy's Avatar
Way2flyy
Yeh it tries to turn over I hear some belts I guess but not gettin to actual start. It's been sittin but My lady generally started it every morning to switch sides in the street. Going to try to jump but if battery was dead, no interior lights should come on right?
hechen507's Avatar
hechen507
When you hit the start button and it tries to crank then you need a jump start.
If you hit the button and nothing happens (crank wise), this happen to me this winter when I haven't drove the car is a few days. I simply turn off all the AC, radio or anything that puts a load on the engine and and tries to start again and it worked.
Old Feb 20, 2013 | 11:14 AM
Way2flyy's Avatar
Way2flyy
Vent valve replacement? ....how would I kno it's that
Old Feb 20, 2013 | 11:17 AM
DeamonG37s's Avatar
DeamonG37s
Will they do that fix with out warranty?
Old Feb 20, 2013 | 11:18 AM
DeamonG37s's Avatar
DeamonG37s
U know its that because your battery is dead. And its 08.
Old Feb 20, 2013 | 11:24 AM
Way2flyy's Avatar
Way2flyy
Dnt think battery is dead, can still work radio and all those things fine
Old Feb 20, 2013 | 11:26 AM
Way2flyy's Avatar
Way2flyy
Tries to crank up but doesn't, tried turning off radio, heat, and all other non essentials, still doesn't start.
Old Feb 20, 2013 | 11:27 AM
Way2flyy's Avatar
Way2flyy
Checked oil, n it was low as well as very dark . Could this be affecting startup?
Old Feb 20, 2013 | 11:29 AM
Rad_Slinger
Yep....and most of the time you'll be able. Having a "dead battery" just means it doesn't have enough amps to turn over the starter.....unless its completely dead, there's gonna be juice left for lights and radio. Also, how old is the battery? Could have a bad cell which would also affect amperage.
Srsly, try to jump it. It's the simplest thing to do at this point.
