Infiniti just put my steering wheel on wrong!!
Old Feb 24, 2012 | 06:55 AM
JOHNNYG37S2008's Avatar
JOHNNYG37S2008
so took it to the shop to get my new steering wheel put on under the warranty,
Got it back and the wheel was not centered. find out like two days later when i actually saw it. So got a email to write a review and i put the truth about my experience there and got a call from the service advisor that was helping at the shop and said that i should of not wrote the bad review because it affects his pay, and should of let him know there. All i got to say i will not be going back there no more and for him to call me and tell me that, He can #$#$ OFF!
Just wanted to post this.
Old Feb 24, 2012 | 07:37 AM
Weiboy718's Avatar
Weiboy718
Did you even let them try and fix it before writing the bad review?
Yes, if you install the steering wheel it can and will be slightly off center and it can be fixed with a simple alignment.
Old Feb 24, 2012 | 08:29 AM
ncpalafox's Avatar
ncpalafox
U should've called first to see what they could do first. If they offer no solution then a neg review would be the appropriate move to make next.
Having said that, the service advisor should not make this about him by telling you not to write a bad review and how it affects his pay.
Old Feb 24, 2012 | 09:53 AM
ImStricken's Avatar
ImStricken
JOHNNYG37S2008:
as i agree that they should have test driven your car, and made sure their work is 100% spot on, but lets agree that humans make mistakes.
take a look at what the steering wheel sits on. if you miss it by one tooth, its gonna be off and a little turned either way. you have to agree that with that many teeth, its tough to be perfect. total human error.
you should have just called and asked for them to make that adjustment. they wouldnt have charged you anything- and it would have taken no more than 20-30mins. no one is perfect, and just because you bought a high-class car, doesnt mean the mechanics are better, more careful, or robots by any means.
Old Feb 24, 2012 | 09:57 AM
Why would you write a bad review about the work before even telling them it was wrong and giving them a chance to fix it? Good luck if you ever need that service department to do you a favor in the future.
Old Feb 24, 2012 | 10:12 AM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
Originally Posted by ImStricken
JOHNNYG37S2008:
The G37 doesn't use this method. Anytime you take off the G's steering wheel, you must secure the back plate from rotating with tape. That's how I did it and worked just fine.
Old Feb 24, 2012 | 10:13 AM
cruzmisl's Avatar
cruzmisl
Uhhh, yeah, what these guys said.
First of all, there have been people TURNED DOWN from getting a new steering wheel.
Second, is this really worth getting that upset about? It's not like they did something to permanently damage your car. It's easy for them to fix, and you just need to ask.
If I were the dealership, I'd tell you to go take a hike.
Old Feb 24, 2012 | 10:18 AM
jjasonSU's Avatar
jjasonSU
Looks like he said he would have someone fix it if u let him know... No damage to your car, no reason to spazz out
Old Feb 24, 2012 | 10:36 AM
Mysticalism's Avatar
Mysticalism
troll alert.... troll alert...
Old Feb 24, 2012 | 10:53 AM
Kevalteam's Avatar
Kevalteam
Okay people calm down~ Can we all just get along?
Old Feb 24, 2012 | 10:55 AM
ImStricken's Avatar
ImStricken
take a look at the steering wheel. i can clearly see splines.
i have never heard of a steering wheel held on by tape.
Old Feb 24, 2012 | 10:56 AM
Weiboy718's Avatar
Weiboy718
Damn! Totally backfired, OP, you better duck and hide the bullets.
Old Feb 24, 2012 | 10:59 AM
Weiboy718's Avatar
Weiboy718
That backing plate he's talking about houses the airbag wiring harness so it doesn't curl up while turning the steering wheel. The steering wheels will still need to hook back into the splines/teeth.
Old Feb 24, 2012 | 11:03 AM
ImStricken's Avatar
ImStricken
you mean the clock spring?
and the splines is what i was talking about. if its off by 1 tooth, its gonna steer in either directions. idk why he even brought up the "backing plate".
Old Feb 24, 2012 | 11:05 AM
ImStricken's Avatar
ImStricken
you mean this?
