How to get better MPG?
Intake and exhaust improvements are worth it, but fairly negligible (1-3?) when it comes to MPG improvement. And, I could be wrong on this, but if you're going to do one you might as well do the other. The intake helps the car breathe in and the exhaust helps it breathe out, you really should get them both to see improvements.
The best method of getting better fuel mileage is changing your driving habits. That doesn't mean you have to drive like an old lady.
A lot of driver's have no idea how bad they drive, as far as fuel mileage.
Most of your mileage is probably being ate up on how fast you approach and leave red lights and stop signs.
Think of the gas pedal as the money pedal. You have to pay to play.
Tom
Tom
I was a bit surprised at how bad the gas mileage was on the car ('11 G37X coupe)
I only drive on the weekends for the most part, so I wasn't worried, but I went from filling my tank once every five weeks or so, to having to fill up every two weeks.
Same amount of driving.
I was driving a Pontiac G6 GT so it's not like I came from a 4 cylinder.
However, if you're going to shell out 40k+ for a car, the extra $$ to put gas in it shouldn't be messing up your budget. If it is, then you aren't living within your means. I'm not trying to say that's your case, but in general, once you spend a certain amount for a car, putting gas in it shouldn't be a big deal.
I just got the car yesterday. I went from 27mpg city regular gas to 16mpg city premium. big change. I knew it would happen and i was expected to get that much but as in hondas, i thought intake and exhausts would improve the mpg a little.
Can someone give me more info about he tune? how do i do it and where do i go to do it?
btw... even 2mpgs do make a difference in the long run to me. because that means im getting an extra like 40 miles a tank haha.
I can't imagine this car getting worse mileage than my 5.7L camaro did ~13-15 city, 21-23 hwy (with 80K miles on the odo). About the only time I'd really get into the throttle was on on/off ramps, other than that, gramma like acceleration, but 10 over the speed limit usually.
Most times, if coming up to a light, rather than downshifting (think sequential gear box) through each gear, just stick in neutral and coast up to the light. If the car ahead moves a few feet, stay put until the light actually turns green. Skipping gears might help too, but be sure to rev match (ie, 1st to 3rd, let the rpms drop enough).
Do folks notice better mpg running premium fuel?
I dont understand how an intake would help with gas mileage.. more air means you need more fuel or you will lean out. Sooo ya kinda makes no sense. I think its more that people drive slower with intake because it sounds nicer at a lower rpm than stock lol.
Haha, civic guys! I drove slow in the civic and i got only 22 mpgs, but when i started driving more aggressive, i got so many more! 26mpgs!
That doesnt work on the g37 haha.
so would the intake improve my gas milage? or would it use up more fuel? Intake and exhaust seems like a bit too much right now. I just got the car 2 days ago. i dont want to dish out a thousand right away but i might spend that 400 for the intake if it would pay itself off in the long run
Ok, ok, ok. If you want better fuel economy, learn to drive better. It's your driving habits, I promise. They make a huge difference. No, I don't mean drive like Grandma. In fact, she probably does a bad job of conserving fuel. Learn how to conserve fuel, then do it.
Want something that doesn't require that you change? Ok, get a lightweight underdriven pulley set. It'll save you some fuel, and contrary to what the next guy is probably going to post, they aren't the devil and won't hurt your vehicle in any way. Get different tires. Yes, some are made with lower rolling resistance and will help your fuel economy. Yea, you'll sacrifice some traction for it, but odds are you won't need that traction if you're worried about fuel economy. You can also increase the air pressure in your tires. Up to about 45 and you'll be fine. Yea, a little harsher ride, but after 5 minutes, you won't notice it anymore. Again, contrary to the next guy's post, higher air pressure won't make your tires fall apart, or wear horribly. I've run with tires up to 50PSI before with no abnormal tire wear for the life of the tires.
Check out websites oriented around increasing fuel economy. There are tons of them, just search.
mjnoles1
Oct 4, 2015 10:27 PM
