Non-Interchangeable parts between Skyline and Infiniti
Old Nov 14, 2011 | 01:44 AM
xfuzion's Avatar
xfuzion
I'm assuming most parts between the Skyline 370GT and G37 coupe are interchangeable, so I'd thought it would be better to phrase the question this way:
Which parts aren't interchangeable between the 370GT and G37?
I'm asking this because I was told that the header positioning maybe different due to LHD and RHD (or something along those lines). Comparing Tanabe US and JP websites (as well as Fujitsubo US and JP), part numbers don't correspond between the skyline and g37 coupe, and in the case of Tanabe, there aren't any listed exhaust parts for the skyline...
Does anyone know of any other parts that I need to be wary of when getting G37 parts for my Skyline?
Old Nov 14, 2011 | 07:02 AM
Presto's Avatar
Presto
do you have 4was (4 wheel active steer)? some exhausts, rear braces, rear camber kits etc dont fit cars with 4was.
Old Nov 14, 2011 | 08:32 AM
xfuzion's Avatar
xfuzion
Thanks for that tip. The 4was notification lights up on the dash when starting the car, so I guess I do have it...
Old Sep 18, 2023 | 04:01 AM
NansGarden's Avatar
NansGarden
Just a follow up queiston on this, do the headlights from the G37 models fit the 08' Skyline 370GT mounts?
Old Sep 18, 2023 | 11:45 AM
rotarymike's Avatar
rotarymike
Moderator in Moderation
Probably, BUT - JDM/UK/AUS are going to aim wrong (left hand drive v right hand drive). So they'll blind oncoming drivers and you won't see much of the ditch on the side. If you're planning on taking them apart to paint/mod, and just want newer housings that aren't sun crazed, just remember to change the projector housing from your cars' original to the new headlight. Otherwise... no.
Old Sep 18, 2023 | 08:55 PM
NansGarden's Avatar
NansGarden
Awesome thank you
Old Sep 21, 2023 | 06:42 AM
mummy2's Avatar
mummy2
I could be wrong but I ASSUME that the headlights are the same and the only difference would be the way they tell you to aim them. I aim my headlights in a way that I don't see the cutoff line on the ground and it appears the pattern is the same on both sides.
Old Sep 25, 2023 | 11:57 AM
rotarymike's Avatar
rotarymike
No - the cutoff shields in the projectors are different. Not sure you can flip them over but maybe.
Florin Tufescu
Other Regions
Oct 1, 2020 08:17 AM
Kozak
Sep 24, 2016 05:38 PM
Kurifu
Mar 5, 2012 01:06 AM
motocopter
Dec 30, 2009 05:26 AM
WRAH
General Tech Questions
36
May 8, 2008 05:54 PM
