Infiniti say go F yourself
Old May 9, 2011 | 02:44 PM
emyrl's Avatar
emyrl
If you have Ichiba Ver 2's and did not do the copper crush ring fix and you are on stock wheels then your chances of vibrating are high. Search up copper crush ring fix and see what to do.
If none of that is the case, then can't help ya.
Old May 9, 2011 | 02:52 PM
ipitythefoo's Avatar
ipitythefoo
^doing that soon! Vibrates like hell!
Old May 9, 2011 | 02:59 PM
Modme's Avatar
Modme
Originally Posted by ANMVQ
car shock be for the drop and spacers just not as bad..
That just means the drop and spacer are causing the shake. What do you the dealership to do? Fix your spring? Fix your spacers?
Old May 9, 2011 | 03:17 PM
ANMVQ's Avatar
ANMVQ
Sorry maybe a said that wrong , the car shock "Stock"
Old May 9, 2011 | 03:21 PM
csnpsu's Avatar
csnpsu
I dont understand you, if it shook before spacers, why didnt you have it fixed???????
ANMVQ's Avatar
ANMVQ
Is that on here??
So do not do a alingment either? Was going to have my mom swing by the alingment place at 4pm.
Old May 9, 2011 | 03:25 PM
In this case the dealer may be right. If it vibrated before suspension mods it would have been better to have it checked out and fixed before performing mods that are known to make a car vibrate. Although its a PITA for you to do, I think it's reasonable for them to tell you to put it back stock before they can check it out.
FWIW, my money is on spacers or wheel balance being the issue.
Old May 9, 2011 | 03:33 PM
breftayka's Avatar
breftayka
Look man. I feel for you and I want to be on your side, but I bet it is the wheels or the spacers causing the vibration. More than likely the spacers. Several people have had problems with the Ichiba V2's.
One quick thing. Check to make sure the OEM studs that poke through the spacers are centered with the channel on the back of the wheel. Hopefully that makes sense to you.
(The Ichiba V2s fasten to the original stud. There is part of the original stud that will still poke past the nut. Make sure that is not hitting your wheel and causing your wheel to go on slightly crooked.)
Old May 9, 2011 | 03:44 PM
ANMVQ's Avatar
ANMVQ
I know thanx man, But he made is sound like put it back to stock and then we will replace the rotors and pad??? We'll I 'm gonna do the alingment anyway( Should be done when dropped).. I just read the copper fix and will try that this Saturday and see what happens..
Old May 9, 2011 | 03:50 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
Rebalnced them twice,, Will try alingment before I get rotors and pads.. Just funny how they are, Look for any excuse to denine work, Even if they can not back it up.
Honestly now - was the car designed to have spacers and be dropped? It does move it to a different level than when it was delivered new. If I were the service mgr. I would request those items be removed and then check the car out.
Old May 9, 2011 | 03:55 PM
soundmike's Avatar
soundmike
Is that on here??
The ring DIY is on 'Driver, a post by Intgr8r. It has solved many a vibration problems caused by spacers on the V36 platform.
Old May 9, 2011 | 03:57 PM
ANMVQ's Avatar
ANMVQ
Thanx soundmike was reading it just a few minutues ago,
Old May 9, 2011 | 03:58 PM
da mayor's Avatar
da mayor
sorry if you knew about an issue you should've fixed it before putting the spacers on. Or you should've just taken the spacers off before you brought it to the dealer to have them take a look at them.
Vibration issues have many variants that can be the cause.... could've be even the rotor, not just a wheel issue. Maybe dead spots in the tires? who knows
Old May 9, 2011 | 03:59 PM
  #29
ANMVQ's Avatar
ANMVQ
I was a service manager for 10 years saw all kinds of modded cars and would only denie the work if I knew 100% it was the issue. We all know that the drop will not cause the car to shake.
Old May 9, 2011 | 04:41 PM
  #30
MurderedG37s's Avatar
MurderedG37s
Oh course it makes sense to bring it back to stock before they work on it. They are obviously going to blame it on the spacers and drop before they begin to pay $$$ to fix your car. Should of had it addressed pre-mods obviously but that point is mute. Sucks but in the end they need to pay for it and they are not going to spend time diagnosing/eliminating potential problems that were possibly brought on you and spend more time than they have to. Sucks but its reality.
