cant install bb grounding kit help!
so i bought grounding kit and unfortuntly cant install it all the way because my engine cover will not come off due to broken bolt on bottom right side. so my question is, since i cant get to the right side is there way i can still have this hooked up for my transmission. i have an auto and mostly got this for better shifts is there anything i can do or are they just useless to me?
i cant make the one on the driver side i think there's only one wire going to driver side thats under the engine cover?
and i tried everything that bolt will not come out needs to be drilled off or something theres no way im doing that
So you just leave the broken bolt? It's really quite easy, just buy an ez-out or left handed drill bit. Soak it in pro lube or wd-40 and let it sit a few hours first. If you wanna get rid of the grounding kit, I can help you with that too. :P
Attach the wire under the very small (8 mm) nut on top of the throttle body. I think you can do that without removing the cover.
Is a bolt head in the cover broken off or can you just not get it to come out?
If your still under warranty though you might wanna have them mess with it. I cant see them cross threading the bolt as you are stating though. You buy the car new? Ever had the cover off before?
I installed mine without removing eng cover,no big deal,like BB said,just use upper throttle body bolt (allen) and route wire behind eng cover, secure with wire ties. It can be done,just a little harder, good luck
