Viper 5902 Alarm / Remote start for G37 $1000?
Old Dec 10, 2010 | 02:21 PM
  #31
123u's Avatar
123u
any pics would be nice!!!
Old Dec 10, 2010 | 08:07 PM
  #32
IntangibleBW's Avatar
IntangibleBW
There's not really any pics worth sharing. Everything is already tucked away and I didn't do the install.
The avital model is 4113 if that helps anyone and I got the work done by good vibrations in horsham pa.
Old Dec 10, 2010 | 11:19 PM
  #33
salerngo45's Avatar
salerngo45
all the vipers 5701,5901,5902 and others all do manual transmissions. and theres basic 1-way viper units half the price of a 5901 that will work with the smart start if you plan on not using the remote. I install on push button cars all the time its not a big deal just takes a little longer
Old Dec 10, 2010 | 11:22 PM
  #34
salerngo45's Avatar
salerngo45
Originally Posted by G37SBS
For those who has Viper 5902 on their G37 how much did you pay for the whole thing? i went to the Viper Authorized Installer in NY L.I. and they quoted me $1000 for my G37S 6MT. It will include tilt sensor addon also. Do you guys think it is a right price and i should go for it or should i shop around for better price?
Thanks
1000 bucks is way to high!!! you looking to do the smart start with it or just a 5902? where on the island did u go? our shop is in medford
Old Dec 11, 2010 | 12:52 AM
  #35
G37SBS's Avatar
G37SBS
5902 with tilt but the shop is Authorized viper dealer... Are you the Authorized dealer too? if so i'll come to your shop if it is any cheaper..
Old Dec 17, 2010 | 04:03 AM
  #36
maxfinity's Avatar
maxfinity
Originally Posted by Mmartin88
Curious do you have an auto or manual?
I have an auto. Sorry for responding so late
Old Dec 17, 2010 | 06:13 AM
  #37
whiddles's Avatar
whiddles
I would get the cheap one way and then use the smart start only for everything else. It has feed back in itself correct?
Old Dec 17, 2010 | 06:34 AM
  #38
maxfinity's Avatar
maxfinity
Smart Start will send a text message to your phone letting you know your alarm was triggered. I have a two way alarm system. Im not sure if a one way alarm system will work the same way. Also i do not advise just relying on the smart start to access your car because sometimes the system gets backed up and your car will not receive the command. Instead you get an error message. This can last for hours. Then when the system comes back up you think your car is going crazy because every command you sent to the car starts to come through. This has happened to me a couple of times. It has gotten alot better since they updated the system but it still does it at times.
Old Dec 29, 2010 | 05:19 PM
  #39
IntangibleBW
Hey guys just an update - I've been having a lot of problems w my remote start and most recently now I've had to jump start my car. The installer did a test on the battery and said the "cca" test failed and I need to have the battery replaced. Took it to my local infiniti dealer and they said that the battery issues falls under a technical service bulletin and will be replaced w a bigger battery and the valve cap also needs to be replaced. The service person told me after seeing the remote start that the electrical issues could be caused by the remote start and so now the electrical part of my warranty is voided..
Ill let you guys know what happens next but just a heads up that it may be more trouble than it's worth. At this point I'm going to get the remote start put back in and will see if I have any more trouble in the coming weeks. If I do ill be removing it entirely and having them replace the harness.
Old Dec 29, 2010 | 05:21 PM
  #40
IntangibleBW
One other note my car only has 11k miles on it so it's still practically brand new
Old Dec 29, 2010 | 09:12 PM
  #41
tWistedMissiOn's Avatar
tWistedMissiOn
Sorry to hear that man, i hope you get it fixed.
Old Dec 30, 2010 | 01:52 AM
  #42
maxfinity's Avatar
maxfinity
Wouldn't they have to prove the remote start caused the problem not just make assumptions? If the dealer would have installed the remote start then would your warranty be void then? Sounds fishy. I would be fighting that one, unless you think the remote start did cause the problems.
Old Dec 30, 2010 | 02:19 AM
  #43
whiddles's Avatar
whiddles
I also had my battery replaced under the TSP. I think your dealer is trying to pawn it off so they don't need to buy you a battery. If the problem was not the battery in the first place they would not have a TSP for it. Its not like your car is the only one LOL
Old Dec 30, 2010 | 07:08 AM
  #44
Deemancpa's Avatar
Deemancpa
So what's the verdict? I'm interested in an alarm, can't tell from the post which one and voids on my warranty.
Old Jan 20, 2011 | 10:25 AM
  #45
IntangibleBW
heres my verdict: don't do it.
i had to have the remote start removed from my car after about a month of going back and forth to my installer. it doesnt work, it was draining my battery, had my battery replaced and had the same issues, and now i'm not sure if i can even trust that everything was removed properly and infiniti says they won't honor the warranty on the "electrical push to start" part of the car
