Is it possible to disable adaptive cruise control?
Old Jul 4, 2010 | 05:02 PM
shumby's Avatar
shumby
Originally Posted by RedG37SNC
I think some folks aren't proactive enough with it or have somenone pull in front of them causing their car to break. I've heard, but haven't tried, that you can apply you accelerator pedal slightly and this will temporarily cause the car to not break in that situation.
yup you just put on the gas and it will keep your speed. it is quite good it will almost bring you to a stop. i have tried this and it will slow you down to about 15km/hr and thewn it beeps at you to say " wtf hit your owen brakes dumb ***".
Old Aug 9, 2010 | 06:08 PM
dooozie's Avatar
dooozie
Adaptive Cruise Control - visible braking?
I have a White Pearl 2008 G37S which I absolutely love. Since the 1st time I brought it in for service, I have asked several of the service reps at the Infiniti dealer where I bought the car, and no one had an answer.
When you are driving with the Adaptive Cruise Control on, and the vehicle slows (and brakes) for the car in front of you, do your brake lights turn on? Simple question, but no answers, so far. Anyone know?
#2 Question and/or problem. When I have the cruise control engaged, and start to go down a moderately steep decline on the highway, it won't hold the speed - it keeps going faster and faster. It will hold the same speed if another car is in front of me so the laser is working fine. They've checked it 3 times, but because there are no steep hills in Fresno, they can't test it correctly. I would have to leave it for several days so they can test it in the hills. What is a gal to do? Thanks, guys
Old Aug 9, 2010 | 06:15 PM
1) I wondered this too so I tested it out. Yes, your brake lights illuminate when the ICC brakes automatically. If you think about it, it has to - sometimes the braking can be very sudden and it could cause a rear end collision if it didn't.
2) AT or MT? I have 6MT and have never had an issue with speed increasing when descending a moderate hill, I have felt the car cut the power to maintain the set speed. Of course if I'm descending a hill of any steep grade I don't use the cruise, so maybe I've never really tested it out, I cant remember.
hispeed-lowdrag's Avatar
hispeed-lowdrag
When ICC slows down, YES, the brake lights go on (I had my friend drive behind me and tell me). It does apply the brakes, and since the brakes don't know the difference b/w you and the ICC, the lights engage.
As far as going down hills...when I have the ICC turned on, my car will obviously slow on hills but when the normal CC is on (no laser), it will not brake at all (which is how it is supposed to work). If your ICC is not slowing on hills that seems something COULD be wrong, I will make sure to pay more attention next time I am on a hill, maybe I am just imagining things.
You said when you have the cruise control engaged...make sure the ICC is on and not just the normal Cruise Control, that MIGHT be the problem (not trying to insult intelligence at all, sometimes we simply overlook the simplest points)
Old Aug 9, 2010 | 06:20 PM
dooozie's Avatar
dooozie
I agree it is only logical that the brake lights turn on. I would have thought the dealer people would verify it. Hmm.
Sorry, I don't understand what AT or MT is. There are a couple of downhills that I have to watch my speed carefully because I know there is a cop at the bottom with his pen and pad in his hand. Speed limit is 70 there so I set my cruse on 70. Before I know it, I'm going 85..... Whoa!
Thanks Black Betty
Old Aug 9, 2010 | 06:22 PM
hispeed-lowdrag
Thanks Black Betty
lol
AT = Automatic Transmission
MT = Manual Transmission
Old Aug 9, 2010 | 06:28 PM
dooozie's Avatar
dooozie
No insult, no problem. I only use the ICC. But, actually, if I was using just the regular cruise control, it should also hold the speed whether it up or down hill. I know cars that I have previously owned (Toyota, BMW, etc) would do that.
Old Aug 9, 2010 | 06:31 PM
Sounds like the hill you are descending is too steep for the cruise to control your speed. Downshift.
Old Aug 9, 2010 | 07:46 PM
dooozie's Avatar
dooozie
BTW it is an automatic. Thanks for your help.
Old Aug 10, 2010 | 12:02 PM
chasemyaccord's Avatar
chasemyaccord
Wow, I love my ICC so I don't get why you'd want to use the normal one instead. +1 for tech package!
Old Aug 10, 2010 | 12:03 PM
hispeed-lowdrag
sometimes you HAVE to use the normal CC. If there is thick fog, the ICC will automatically shut off. Or if the windshield wipers are on any setting faster than the first adjustable speed, it will shut off. Also, if you are on a long trip and the laser gets dirty it will automatically shut off.
Old Aug 12, 2010 | 05:30 PM
MrMichael's Avatar
MrMichael
Also if you are driving into morning or evening sun and it is at that perfect height the laser will get confused. Had that happen once and took me a minute to figure out why cruise shut itself off.
Old Aug 12, 2010 | 06:54 PM
G37SBS's Avatar
G37SBS
I have few question about ICC ...
i try to set the speed for ICC and i can't do it..
I have 6 speed so which gear should i shift then turn on the ICC? or is it only works in 6th gear?
How good is the ICC? if someone cut me off in the high way the ICC will brake me immediately?
i'm sure it will not change the gear automatically when the car slow down tho right?
Old Aug 12, 2010 | 07:31 PM
  #29
advan37's Avatar
advan37
any gear but speed should be above 35 miles (60 km) .
Old Aug 12, 2010 | 08:11 PM
  #30
It works in any gear. Cruise shuts off if you change gears though, you'll have to reset it.
Mine works fantastic. The only glitches have been when the sensor was very dirty. If someone cuts you off in your "following distance" the ICC picks it up instantly and brakes accordingly. If it's at the far range of the distance you have it set to and they are going almost the same speed as you have set, it brakes slightly to match their speed and then speeds back up as they do. If someone cuts you off really close or is going a lot slower it slams the brake hard.
If you have a manual, obviously it wont shift to a different gear, it's a manual transmission. You have to shift it yourself.
