Hit a pothole and airbags deployed! Help!
when you hit the pothole at the speed you were going was there like alot of vibration in the cabin. If the vibration passes a certain level on the air bag sensor then they'll deploy. As for the passenger airbag do you have to manually set it off or is it automatic.
lawyer because 1) your without a car for almost a month that is if you have another one waiting. 2) It's a defect and it should be placed under warranty.
I admit Infiniti customer affairs is crap. They take for ever to resolve a any kind of matter.
It's manual. Basically, you just have to be prepared. 1/20th a second before the impact of a crash, you have to push the "Deploy Airbag" button(RTFM to find it). You need to have pretty good reflexes. I've gone through 2 wives trying to get the timing right, but I think I got it now.
THis is terrible. I have had no problems with Infiniti for the two years I have had my G, but somehow I bet I'd get the same runaround if this happened to me. Airbags shouldn't deploy from hitting potholes, end of story. This should be covered under warranty....
Not only should you be getting a lawyer you should stop talking to Infiniti Corporate, stop talking to Infiniti Dealers and stop posting on the internet about it. But then again your lawyer should have already told you this. Get a lawyer and he/she should be doing your talking for you from now on.
Not to be insensative as I'm not experiencing deployed airbags but, how is the airbag deployment sensor supposed to know when it is a pot hole and not an impact with something stationary or head-on? Really. The wheel was broken - that was not a small pot hole either to break a forged wheel. Every pot hole I've ever seen has had the dirt and gravel flushed out of it leaving the face of the asphalt as a vertical edge for the impact. Tough for an impact sensor to sort out.
In this case, the Infiniti bashing has started publicly before Infiniti had a chance to resolve the case. Sure they aren't by any means moving swiftly on this and that is problem.
Sorry, I still don't understand the chatter about the whether the passenger bag should have deployed or not. I'm suspecting not if no one is sitting there.
Infinti has a very bad customer service unless you find that rare dealer. I miss Santa Barbara Auto Group for my warranty work and service. The Oxnard dealership service was a nightmare and about 50 minutes away from my house. If this treatment continues I may sell this car and never buy a Nissan automobile again. If you buy a premium automobile you should get great customer service from the dealership and the manufacture. Check out the link below.
http://www.leopoldkuvin.com/Practice...Litigation.asp
System malfunctions
There have been numerous reported instances (and recalls) of air bags because of unnecessary deployment (on ignition, upon striking a pothole or curb). These are typically caused by a problem in the electrical system or sensors.
System malfunctions
Haven't had any problems with Grubbs Infiniti in Euless regarding service work. However, haven't had anything as extensive as a airbag issue.....sorry to hear. Hope they get the situation rectified.
I'm not a mechanical engineer but I believe this is how it all is supposed to work.
