Jacking points
Old Aug 9, 2009 | 06:47 AM
sundance555's Avatar
sundance555
Jacking points
I just gought a new floor jack for my 'o8 G37 coupe. Can anyone help me with location of jacking points other than those used with the stock jack?
Old Aug 9, 2009 | 12:02 PM
SkyMG37x's Avatar
SkyMG37x
According to the service manual, the front jacking point is the cross member between the front wheels just aft of the oil pan cover, and the rear point is the differential case. I'll differ to someone that's actually lifted the car and can confirm.
Old Aug 9, 2009 | 12:34 PM
Weiboy718's Avatar
Weiboy718
YES! those two points are correct but then if you're lowered like alot of us there's no way we could get our jacks under there.(except for our rear)
Old Aug 9, 2009 | 01:43 PM
Greggski's Avatar
Greggski
I just use the location where the stock jack would go. For the front, they are behind the front wheels along a pinch weld under the rockers. Look for two little indents in the seam. The rear is in front of the wheels. If you have a floor jack with a plate that swivels on the top and it has a lip on it, take that off or it can bend the seam that you are using to jack the car up.
Old Aug 9, 2009 | 02:14 PM
speedracer g37's Avatar
speedracer g37
i'm lowered and use the stock jack to get the car up enough to put the floor jack under the crossmember.
fuzzed
Aug 21, 2020 09:35 AM
Prometheus
General Tech Questions
Nov 9, 2015 01:23 PM
Landshark
Sep 29, 2015 11:20 PM
Chappedj
Sep 28, 2015 03:20 PM
