Top Gear - European G37 test
Cruising on the freeway at 3200rpm sucks when the 3series BMW (the competition that Infiniti is targeting) is running at 2800.
We all know what to expect from this car. It shouldn't be a surprise to anyone. However, ppl are just hoping that the 7AT would help a little bit. NO ONE IS EXPECTING 10mpg increase with the 7AT but every little bit helps.
The extra gears will likely do more for the purpse of helping with engine noise at cruising speeds and give it a couple of extra grinding gears in the middle. It is also a good marketing strategy.
Much depends on what the final gear ratio is in determining what the exact benefit will be.
What the heck is the 0-60 on an '08 6MT coupe given the sedan with 306hp and a little less weight pulled off a 5.3 second.
It feels faster than my '05 G35 coupe 6MT and that car I could shift flawlessly.
They tested a 6mt.
The euro car will cost more than Infiniti thinks we'd like to pay. Just wait till the pricing comes out and do a conversion from euro to US dollars and see how much it could cost you to buy one of those and it'll be obvious why they are getting upgrades.
I wonder if we'd all choose to pay +$5k for our cars if we got these niceties? Maybe this is the sort of thing a true Premium package should be for.
There's still a slim chance that there may be some noticeable increase in fuel economy. I've noticed that Nissan/Infiniti uses 3 different final drive ratios in their FM vehicles: 3.357; 3.538 and 3.692. The FX35 AWD tested uses the 3.692 axle ratio and does 60mph at 1960rpm in top gear. And the 3.357 axle is what the FX35 RWD uses. If my guess is correct, the 3.357 will bring down the rpms@60 to about 1750 or so correct? I say let's wait and see what the deal is on the FX35 RWD before we make a final judgement call on the new 7A. I'm hoping and praying that Infiniti will have the wisdom to use the 3.357/7A combo in the G37S coupe.
I personally don't expect a major jump in gas mileage, but it would be great for me if the G37S 7A could squeeze out 28+ mpg at 75mph.....
JoshB
Oct 15, 2015 03:08 PM
Sway_NV
Aug 15, 2015 09:36 PM
