Launching + Shifts (5AT)
Old May 11, 2008 | 09:00 PM
LAG37's Avatar
LAG37
this might be a repost but plz tell me what u do
im riding with an auto tranny
whats the rpm that u rev it up to for the perfect launch?
also
when ur dragging (at the track) on a straight away do u drive with DS or Tip?
which is faster?
DS or Tip
thanks!
Old May 11, 2008 | 09:38 PM
Dieseldoug22's Avatar
Dieseldoug22
The last time I dragged the car, I tried DS mode and manual. And the DS shifted at redline. It is too hard to try and shift at redline without hitting the limiter. And since the DS shifts at redline I can't see any reason not to just use DS. As for the launch RPM from what I heard 3000 is good. I tried an idle start and a start at about 1700 RPM and I shaved about .1 sec off the 60' times.
And FYI, I did a VDC on and off run and the times where almost identical all along the track.
Old May 12, 2008 | 12:42 AM
LAG37's Avatar
LAG37
bump
Old May 12, 2008 | 12:46 AM
LAG37's Avatar
LAG37
5 AT please give me ur thoughts
Old May 12, 2008 | 01:16 AM
G-WIZ KID's Avatar
G-WIZ KID
leave in DS. Rev to 1300rpm. Let her rip. vroooom
Old May 12, 2008 | 01:27 AM
sTiLLBaLLiN37's Avatar
sTiLLBaLLiN37
Former Prez of LA G'Z
LA...sick avator bro damn
Old May 12, 2008 | 01:24 PM
kg37's Avatar
kg37
use DS mode. Like dieseldoug22 said, it shifts right at redline.
Old May 12, 2008 | 01:53 PM
vinnys coupe's Avatar
vinnys coupe
one says 1300 one says 3000 lol thats a big diff..
Old May 12, 2008 | 01:56 PM
The1andOnly's Avatar
The1andOnly
He should have some fun testing which works for him
Old May 12, 2008 | 01:59 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
3000 is too much in most conditions. That will build up too much heat in your tranny and unless you break traction it will cause the TQ converter to bog. Either way that's not good when dragging (breaking traction too much or boging down)
1300 is the most I would rev up to.
The best time I've seen was VDC off, just slam the gas shifting in MM(timing had to be perfect in 1st gear)
The TQ converter in this car has high stall speed so extreme brake torquing in this car will have only minimal effects if any.
Old May 12, 2008 | 08:36 PM
LAG37's Avatar
LAG37
thanks!
Old May 12, 2008 | 08:44 PM
Blackjack's Avatar
Blackjack
DS Mode FTW.
Old May 12, 2008 | 09:27 PM
LAG37's Avatar
LAG37
so the best launch is in DS?
Old May 13, 2008 | 03:56 AM
Mr_Ryte's Avatar
Mr_Ryte
Ummm...yeah; at least three people have said that....
Old May 13, 2008 | 12:47 PM
Mike's Avatar
Mike
DS + mash the gas without any brake torque seems to work best in my experience.
I'm not a drag racer though...
