G37 Dyno Up on Automobilemag.com 50+ HP
Old May 22, 2007 | 08:49 PM
  #181
Hypnoz's Avatar
Hypnoz
Originally Posted by AlterZgo
Curiously, the Vishnu Xede/Procede on a 335i actually runs a richer A/F ratio. Here's the link to their initial tuning where they mention they are making substantially more power while running a richer than stock A/F ratio:
http://www.e90post.com/forums/showthread.php?t=30027
As for twin turbo setups being unreliable, I would say they are probably less reliable than single turbo set ups (increase the number of turbos and associated plumbing = more things that can go wrong). However, with that said, parallel twin turbo setups, such as implemented on the 335i, are reliable. I ran my modded twin turbo 300ZX very hard for over 60K miles on larger turbos, injectors, dual intakes, etc. without the slightest hint of any engine problems. This included extended high boost running for long, sustained periods.
You get into reliability issues with stuff like the Mazda RX7's twin sequential turbochargers or cars like the Shelby CST? with the variable vane turbos and such which add more complexity to the system.
That is an old post on their initial tuning. I would like to see their a:f ratio's they use now that they are selling the procede to the public. Either way, you are running more HP through the engine and drivetrain. 60k miles on one car with no issues is not something I'd consider hard evidence for the reliability of TT setups.
I understand what you mean though, they can be reliable. Anything can be reliable.
Old May 22, 2007 | 08:52 PM
  #182
Pearlcoupeg35's Avatar
Pearlcoupeg35
Originally Posted by paranormal
man wtf.. i was all set on the audi s5 even the 335i and now this.. wtf damnit
HAHAHAHA....couldnt have posted it better myself Jimmy!
I might just never buy a car again and just look at all the **** coming out....its like cell phones & sh#t now. You think you got the hottest thing and then a week later its old news.
Old May 22, 2007 | 10:38 PM
  #183
OCG35's Avatar
OCG35
Wow, this thread has gone off the deep end... reading this is flabbergasted. I'm speechless at much of the garble going on here.
Old May 22, 2007 | 11:22 PM
  #184
jnmunsey's Avatar
jnmunsey
Originally Posted by Geez35
And you shouldn't even have a can of beer while driving. Stupid.
Huh? Everyone's dad had one in between their legs in the 70s. If my Dad did it I know it is ok.
Old May 23, 2007 | 07:27 AM
  #185
chilibowl's Avatar
chilibowl
Your dad must have smoked crack in his earlier years and blew the smoke in your face when you were a child. I hope youre being sarcastic kid...
Old May 23, 2007 | 07:31 AM
  #186
chilibowl's Avatar
chilibowl
Originally Posted by Hypnoz
Actually you have it backwards. Turbo engines run better in the summer and in higher altitudes than their N/A counterparts.
Are you serious? Why would turbos perform better with HOTTER and LESS denser air? That doesnt make sense at all...I guess Intercoolers are just a novelty to make your front bumper look nice...
Old May 23, 2007 | 09:15 AM
  #187
Mr_Ryte's Avatar
Mr_Ryte
+1.
Old May 23, 2007 | 09:16 AM
  #188
muscarel's Avatar
muscarel
I think the altitude thing doesn't affect turbos as much because the turbo can still achieve the same discharge perssurization regardless of the inlet air condition.
I do not agree about the higher temps though. The intercooler suffers greatly as a result.
Old May 23, 2007 | 10:17 AM
  #189
trey.hutcheson's Avatar
trey.hutcheson
I don't think he's saying that FI cars run better in the heat. I think he means that FI cars don't suffer from less dense air as much as naturally aspirated cras, which is true.
Old May 23, 2007 | 04:33 PM
  #190
wyatthanson's Avatar
wyatthanson
Hypnoz and Trey are right.
An FI car will run a set PSI, fact. If the air is less dense, it will still spool up to the same PSI (maybe take a little longer). Atmospheric pressure at sea-level is about 14 PSI, I think. Go into the mountains with an NA car, and the pressure drops - you feel it a LOT more in an NA car, because now your car is running less "PSI".
Heat kills both.
Old May 23, 2007 | 07:44 PM
  #191
Hypnoz's Avatar
Hypnoz
I recommend howstuffworks.com. Should clear up your misunderstanding of how turbos work.
I did not say they run BETTER in heat. I said they run BETTER in heat than N/A engines do. And they run better in higher altitude than N/A engines do as well. It's all about air density my friend.
Old May 23, 2007 | 08:23 PM
  #192
Initial G's Avatar
Initial G
I agree with all of your assertions EXCEPT the comment about turbo-tuned cars running better in heat than N/A. From my experience, this is quite the opposite. The 335i/G37 test. After a long day of running, the N/A motor withheld the pounding of abuse. So, if it is all about density my friend...then that would make the air more dense and all that will be forced into the engine will be hot air. Hot air = expanded molecules that take up more room.
The increased elevation theory does make sense. The higher up, the "thinner" the air. Air shoots into the motor a lot easier.
Old May 23, 2007 | 09:47 PM
  #193
picus112's Avatar
picus112
This thread is both interesting and hilarious at the same time. A+.
Old May 24, 2007 | 04:52 AM
  #194
jnmunsey's Avatar
jnmunsey
Yeah right.. crack cocaine in the 70s... FYI everyone drank beer and drove in the 70s. Ok well a LOT of people. It was legal in most states.
Old May 24, 2007 | 08:42 AM
  #195
chilibowl's Avatar
chilibowl
And we are in the 2007's buddy....Almost every week out here in Florida there is an accident caused by a drunk driver. Get real....honestly
