Valve Cover and Rack & Pinion Repair cost- combined $2800 is that right?
Old Oct 24, 2023 | 01:45 PM
jeremy1210's Avatar
jeremy1210
Yesterday, I had my 2011 G37S in the shop for a brake and radiator flush and as they were looking around they noticed a leak around the DS valve cover and the DS rack and pinion leak. It's mid $900's for the valve cover replacements and $1900 for a new rack and pinion. See photos. Is this something that needs to be replaced ASAP? Does the pricing seem accurate these days? TIA
Old Oct 24, 2023 | 09:42 PM
beefychicken's Avatar
beefychicken
Wouldn’t be too concerned about the rack leak unless the car is extremely low mileage ... less than 30,000 miles.
If it were mine i would clean it with break-clean or something and see how bad it is leaking over the next 5-10K miles. Just keep an eye on your power steering reservoir level. If the level stays up and there is no significant leakage, i would ingore it.
Now the valve covers are a different story, definitely get those seals replaced once you start to see evidence of a leak.
Old Oct 25, 2023 | 09:31 AM
dkmura's Avatar
dkmura
20 Year Member
I'd also suggest looking in your local area for a business that rebuilds steering racks. They'll take your older rack as a core when it's time to replace it, and the savings (over a new one) can be substantial. Check for valve cover pricing at a source like Rockauto.com for your G. Remember that costs in your area may be slightly higher or lower than other US cities. For Denver, where I live, $2,800 is probably a good ballpark figure, as both projects take quite a bit of labor to do correctly.
Old Oct 25, 2023 | 01:16 PM
PDG's Avatar
PDG
FYI, I had the passenger side valve cover gasket replaced for ~$450 earlier this year at an independent shop. They reused the valve cover itself as it still appeared good when they removed it.
Old Oct 25, 2023 | 10:13 PM
petemo94's Avatar
petemo94
I’d also check and replace the Pcv valves too.
Often times the Pcv is forgotten, resulting in it being clogged and putting pressure into the valve cover - causing leaks.
Definitely don’t put the old pcv’s back on the newly sealed valve covers.
Old Oct 26, 2023 | 12:46 PM
jeremy1210's Avatar
jeremy1210
Thanks, so when I have a shop do this, they'll replace the valve cover and the gaskets? Just want to make sure I get this right with them. Also, have them replace the PCV valves while we're at it. Thanks!
Old Oct 26, 2023 | 12:53 PM
petemo94's Avatar
petemo94
Thats right. The PCV valves are simple enough to change and are $10-15 a piece. For something as vital as engine back-pressure and pressure-relief, I'd pay a little bit extra for an OEM PCV. Good luck and report back.
Old Oct 26, 2023 | 01:46 PM
jeremy1210's Avatar
jeremy1210
Well, inflation has hit the valves too. ~$20 per valve these days. But, I'll order a pair. Thanks!
Jasonkush100
May 16, 2024 12:25 PM
AccordULEV
Jan 10, 2024 10:57 PM
Jhaby
Jan 12, 2021 09:12 PM
Chris05
14
Mar 29, 2017 11:21 AM
ThebigJ
Jan 27, 2017 07:48 PM
