Wheel sizes for boosted vert
Old Apr 2, 2023 | 05:08 PM
Tbchalmers's Avatar
Tbchalmers
I am about to get my ‘12 vert sport boosted and that means stock rims aren’t going to cut it. I would like to go to a 19x10.5x30 in the rear. Can I do this without rubbing on stock suspension? How about 11”?
I know that there are differences between the coupe and the convertible and I rarely see anyone running wider wheels on a vert.
Also interested in if people are running coil overs? Looks like BC is the only one that makes them for convertibles. Thanks!
Old Apr 6, 2023 | 05:33 PM
kiseliok's Avatar
kiseliok
G37 Community Team
Hey, welcome back to the forum!
There are a few people running (or did run) 10 / 10.5 / 11 wide in the back. It's not ideal, but definitely doable.
The easiest way to find these post is forum search - when you are looking at the vert section, you can search just this section from the right top menu "search this forum".
There were 3 different options for coilovers, from what I've seen, but BCs have been the most reliable. That's what I'm running, although had to step up the spring rates.
Old Jul 30, 2023 | 12:35 PM
BOOSTTT's Avatar
BOOSTTT
You can get 11's on there with no problem. Look a Fitment industries for many pics and combos that work. 11X19 with 22 offset I'm thinking...Tires can be pretty wide, but thinner would reduce any rubbing.
Old Dec 7, 2023 | 11:08 AM
jeremy1210's Avatar
jeremy1210
When you say "There are a few people running (or did run) 10 / 10.5 / 11 wide in the back. It's not ideal, but definitely doable." What is not ideal, but doable? What max size do you recommend F&R? I'm 6 months in to the G and I'm looking at the Nismo V1 and wondering how the 10.5 in the rears will do with the Feal Coilovers I'm getting installed in January. I appreciate your knowledge.
Old Dec 9, 2023 | 11:08 PM
kiseliok's Avatar
kiseliok
G37 Community Team
If you go 10+, you need to dial in your offset perfectly, whether with custom fitment or spacers. Because of the way suspension travels, 11x20 were clearing fenders without issues, but they rub on the liner at near-full compression.
Like boosttt recommended - look for FI or maybe even insta for various configurations.
dtaylor72
G37 Convertible
Jun 16, 2012 05:37 PM
G37V
Picture Share G Vert
14
Dec 7, 2011 10:34 AM
Fezzik
G37 Convertible
Apr 30, 2011 04:35 PM
Fezzik
SouthEast
May 3, 2010 02:17 AM
