Anybody have a clue on where this leak is coming from? It doesn't happen every time I go through an automatic car wash but it is starting to happen more often, and it is accompanied by a temporary malfunction of the blower motor it doesn't seem to want to come on consistently just after a wash.
I took the vert through an automatic wash once (long time ago) and vowed to never do it again. These seals are not good with forced water from various angles. I recommend to not do that to avoid bigger issues in the future.
I found some water dropping near the newly installed BCM. I took out the glove box and checked to see where the water was coming from. I did discover water inside the blower motor. When I took apart i found a rust like this. No idea how long this been leaking but i am sure it's been a while. I cleaned it dry and I went over to the engine area and discovered that water indeed was dripping thru the in cabin vent. I tried to cover it up with aluminum foil (grill). When using the fan with outside air it was making noise because not enough was getting inside the vent. So, I purchased Amerimax 4in x 8in Aluminum step flashing(little thicker) from Lowes Item #44834 Model #68708BX and covered up the hole. I am waiting a big rain storm to see if this indeed sealed it. I am pretty sure no water gonna get thru this.
Instead of getting a new windows cowl (I couldn't find any good used one), I covered it up. Also I also brought brand new fastens to hold cowl in place and battery divider. I do believe this helps to put cowl in it's place. blower motor
