Body piece under the door stepped on
A kid stepped on it and it made a pop sound. I can see some plastic clips broke off. It's OK to drive right now but I would like to fix that. Anyone else dealt with it?
This diagram might show some of the pieces that you are looking for.
https://www.infinitipartsdeal.com/pa...agram=767_A005
You might have better luck asking in the general body section.. or maybe search for aftermarket install instructions? Even if these side skirts are a bit different, the idea should be the same.
Without pics, it will be difficult to judge the type/level of damage the side skirt sustained. For example:
1) did the clips just pull out?
2) did the tabs that hold the clips break?
3) did the skirt get cracked /physically damaged?
Depending on the damage, it might be a easy fix or a costly repair. If the tabs are broken, and the skirt needs to be replaced, that will be a simple yet costly fix- especially if you have a "hard to find" paint color.
My paint is the malbec black paint. Not fun to find.
You might want to check out this thread on installing the Aero skirts. https://www.myg37.com/forums/d-i-y-i...t-install.html You can see on the second page the skirt removed and where the tabs go. I replaced my stock skirts with the Aero kit and would probably just take the whole skirt off and replace the tabs. It should be a really quick and easy job. Just order some additional tabs in case they break when you remove the skirt.
