Trunk open error and diagnostic tools
Old Apr 27, 2021 | 11:28 AM
Papa 10's Avatar
Papa 10
Thanks so much. That will be a purchase that will give us great piece of mind on the road by not fearing to use the top. And we always carry a laptop anyway.
Happy motoring and enjoy the summer!
Old May 4, 2021 | 05:45 PM
NaptownDave's Avatar
NaptownDave
Originally Posted by n559br
The package I bought came with a disk drive. I just threw it into an old toughbook I had. I was able to diagnose the top within an hour. It has been the best thing I've got for this car.
I ended up doing the same, but when I hooked it up to the OBDII port the Consult software isn't recognizing my car either through VIN lookup or searching by name. The version is 75.20 and it has later model years available, so I feel like I'm missing configuration files or something. Any ideas on things to try or guides to using Consult?
Thanks!
Old May 4, 2021 | 06:34 PM
n559br's Avatar
n559br
I never used the vin lookup. I just select g37 and the model year. I don't know if it will just pop open your car based on vin.
Old May 7, 2021 | 09:33 AM
NaptownDave
Well, turns out I'm just not that bright and the country location was set to Japan instead of United States. Everything popped right up after I fixed the system configuration and I'm now dangerous with sensor management!
Old May 7, 2021 | 07:13 PM
n559br's Avatar
n559br
Glad to hear it's working for you. I've had the trunk open issue the last couple of days so it's time to get the unit out and diagnose the root cause.
Old May 8, 2021 | 04:11 PM
NaptownDave
Good luck. Since getting the kit working I’ve had the top up and down at least four times with no trouble, naturally. I did notice the battery voltage seemed a bit low, so broke out the multimeter after a long drive and found the resting voltage on my six month old Diehard Platinum 24F battery is 12.1V. Oh, I called it all sorts of names.
Old May 9, 2021 | 03:12 PM
kiseliok's Avatar
kiseliok
G37 Community Team
The battery seems to be one of the major culprits for top issues.
I've been testing mine monthly and although it's been steady, it doesn't hold charge like it used to so I'm eyeing a new 24F as well.
Let us know what you end up with.
I was looking at drycell ones like optima, but I'd have to go with a 35.
Old May 9, 2021 | 04:57 PM
n559br's Avatar
n559br
I have not had good luck with the Optima batteries. I went with it on my last track car as you could mount it in any orientation. But it didn't have a long life. I think I would stick with a good brand AGM or wet cell battery. I'm currently running interstates in my boat for the 2 starters and big deep cycle Advance Auto for the trolling batteries. The golf cart has Trojans. I think the most important thing is maintenance. Keep the terminals clean and if they're wet cells then check the water regularly.
Old May 9, 2021 | 11:16 PM
NaptownDave
I had heat kill an Optima prematurely on a long road trip, on a red top when I should’ve been using a yellow top, but other than that I’ve had good luck with them.
I figured I’ll see if I can find an Interstate AGM locally, then if I need to make a call on a second option depending on what’s available.
Old May 11, 2021 | 05:28 PM
Crunk's Avatar
Crunk
As far as batteries go I have had good luck with duralast gold tops.
Old Nov 10, 2021 | 09:12 AM
My09G37vert's Avatar
My09G37vert
So I just bought the Consult III Plus device and software from China for my top that froze during a cycle when the battery died. Did you use your Consult software to fix your issue or just diagnose? Pretty sure my top needs a reset / relearn. Wondering if you have reset instructions?
Old Nov 10, 2021 | 10:55 AM
n559br's Avatar
n559br
I suggest you get the online service manual as it has all of the instructions necessary. I can print them out for you later today but I'm swamped with work at this time.
Old Nov 10, 2021 | 05:00 PM
My09G37vert
I would really appreciate that. The car has been sitting in the garage for 2 months and I'm hoping this will work. Not much out there showing how to reset the top..... Thanks!
Old Nov 10, 2021 | 05:03 PM
  #29
n559br's Avatar
n559br
Shoot me a pm with your number and I'll give you a call to better understand what is going on and get you in the right track with consult.
flipmode007
Dec 3, 2014 01:14 PM
chitty
Jun 7, 2014 11:36 PM
Roan de Rossi
G37 Convertible
13
Sep 5, 2013 09:06 PM
sneakers
Oct 15, 2012 02:21 PM
xeroed
Aug 26, 2008 10:48 AM
