Spoiler with our without antenna
Old Feb 20, 2019 | 06:39 PM
steakpowered's Avatar
steakpowered
Spoiler with or without antenna
Just bought a 09 G37 convertible and the guy said the antenna doesn't work. I searched around and found that it's integrated into the spoiler. I have a spoiler in mine but thinking the antenna might not be connected.
Is there a specific year that had the antenna? Anyway I can tell if my spoiler has the antenna without taking it off?
Old Feb 20, 2019 | 06:48 PM
teahead's Avatar
teahead
Do your's have the pigtail thingy antenna on the trunk?
Old Feb 20, 2019 | 06:49 PM
teahead's Avatar
teahead
You have no am/fm reception coming out the radio?
Or is he talking about the navigation antenna?
Old Feb 20, 2019 | 06:57 PM
steakpowered
No am/fm antenna. Xm and nav work fine. See pic below.
Old Feb 20, 2019 | 07:03 PM
teahead's Avatar
teahead
I dunno. I'm confused too.
If you look on ebay, there are dozens on there; some with Nav, some w/backup camera, some w/antenna...I have no idea all the combinations of spoilers one can get.
I bought one w/Navigation, but who knows if now that will screw up my am/fm or backup camera. haven't installed it yet.
Old Feb 20, 2019 | 07:04 PM
teahead's Avatar
teahead
I think it depends if you have a 2009-2011, or 2012-2013.
And what options you have.
Old Feb 20, 2019 | 07:06 PM
steakpowered
09 with nav and backup camera. The ones on eBay only mention satellite antenna.
Old Feb 21, 2019 | 07:57 PM
rdog's Avatar
rdog
I have a similar spoiler and antenna that I put on my vert. The little puck like item on your trunk is your antenna. I forgot to connect it when I did my install and am/fm stations would not work. Had to pull back the liner on the trunk lid back by the spoiler again and connect the cable from that antenna to the wiring that goes with the camera which runs back to your audio unit in the dash.
Old Feb 21, 2019 | 09:25 PM
steakpowered
Cool! I'll do it when it stops raining. How long did it take you to pull the liner off?
Old Mar 2, 2019 | 11:52 AM
steakpowered
Pulled the trunk liner off and everything seems connected. Do you know which cable it is?
Old Mar 6, 2019 | 06:30 PM
rdog's Avatar
rdog
I'll try to take a look at mine this weekend. If I recall, the connection I forgot to make was just right of center of the trunk if you are looking at the back of the car. I thought there was a channel opening back by the spoiler but can't remember for sure.
Old Mar 6, 2019 | 07:08 PM
steakpowered
I found the instructions and it does look like I'm missing a ground. From 13.1, it looks like I'm missing the A-B wire. Is Point A the nut that holds the spoiler to the trunk?
This ebay post also has some good pics, but I don't see that cable with the green wrapping at all anywhere. Hoping the rain settles down here and I can take a look at it this weekend.
Old Mar 6, 2019 | 07:34 PM
rdog's Avatar
rdog
I think I skipped step f and had to take the liner off to make that connection before the radio would work......good luck.
Old Mar 6, 2019 | 07:46 PM
steakpowered
After looking at my picture, it definitely looks like the grounding is screwed up. I'll have to tear it apart and rewire it to look like the instructions. It might explain why my backup camera is a bit blurry too.
Old Mar 8, 2019 | 05:47 PM
steakpowered
Fixed it! The ground was on the wrong nut. However, the other nut is supposed to be the back up camera ground according to the instructions but I couldn't find anything like that. Is the back up camera for the vert different?
