Vert Spoiler Disaasembled
Old Apr 1, 2011 | 01:32 PM
cvipgo's Avatar
cvipgo
The OEM spoiler is made of double ABS shells. External shell and internal shell is bonded and held with 7 screws.
Internal shell holds rear view camera, rear light module and the integrated antenna module.
Here are photos to digest thru:
Rear view Camera in the spoiler:
Rear Light module in spoiler
Integrated Antenna Module & location
Disassembled Light & Antenna module
Camera Removed:
Additional photos:
I can see why these were obsoleted and may have issues:
Pros: Adds nicer look, integrates antenna and gets' rid of whip antenna pod replaced with sat antenna pod.
Cons: Repair rework expensive, as every time the spoiler has to removed from the car to replace rear light, camera or antenna module, the double sided tape is not reusable and has to be refurbished- not the case with chrome spoiler - which can be removed any time and reused without the issues of double sided tape. Too many holes in the trunk that can leak. IF the spoiler comes loose at internal shell or external shell - you just can't replace it with chrome spoiler, you have to get the spoiler - expensive and risk of stuck with holes in the trunk.
Hope above helps the vert owners to make their decision on to get the spoiler or not. Ask me if you have question, i'll be glad to answer.
Old Apr 1, 2011 | 07:44 PM
Shane D's Avatar
Shane D
Question
Sounds like they're pretty crappy. So have you torn yours' off your car?
Shane D
Old Apr 1, 2011 | 08:06 PM
katfish711's Avatar
katfish711
Really appreciate your teardown and analysis.
I like the way the discontinued spoiler looks but the downsides regarding replacement of internal parts sure sounds like a bummer.
Old Apr 1, 2011 | 09:38 PM
cvipgo's Avatar
cvipgo
Shane D
I bought/installed mine in August 2010 (I was the first vert owner to do self install ) so I'll wait till it craps out and then decide what to do till then I'll keep and enjoy So. Calif weather with top down.
good luck with yours.
Old Apr 1, 2011 | 09:42 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
nice write up
Old Apr 1, 2011 | 10:37 PM
ESSRTEE8's Avatar
ESSRTEE8
I don't see how replacing double sided tape is a huge downside to doing a repair. And the grommets look to be substantial, more so than spoilers I've had on other cars I've owned.
I'm not sold on the down side of buying one of these and putting on my car.
Old Apr 1, 2011 | 10:38 PM
ESSRTEE8's Avatar
ESSRTEE8
Buy 2 and you will have all the replacement parts you need.
Old Apr 1, 2011 | 10:44 PM
cvipgo's Avatar
cvipgo
great idea.... why not
Old Apr 2, 2011 | 08:54 AM
bschurr's Avatar
bschurr
Yes - nice write up.
These spoilers are OEM from Nissan. The probability of an internal part failing is very, very small (about as likely as your OEM clock failing). All the connections are in harnesses and the spoiler itself, when properly installed should last for the life of the car.
I suspect that the issue with these spoilers is that a few dealership mechanic hacks installed these on some early verts and did so without reading the instructions because they installed several on coupes and sedans previously. Subsequently, there were issues and the dealers blamed it on the spoiler and not the tech.
No proof, Just my $0.02 and my personal conspiracy theory!
Old Apr 2, 2011 | 09:36 AM
cvipgo's Avatar
cvipgo
Thanks B, good input!
I thought let me photo document the construction details of the obsoleted spoiler and let the vert owners/lease holder make their own decision....
The only difference between coupe and convertible spoiler is the integrated antenna module in the vert spoiler.... so why would Nissan make convertible spoilers obsolete and not coupe's? A reasonable question!
No OEM will not discontinue/obsolete a product based on installer's incompetency. there has to be more than just screw-up by installers.
Time will tell.
RexHavoc
Oct 2, 2015 11:47 AM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
