G37x Loaner
Old Sep 4, 2010 | 10:42 PM
evster5's Avatar
evster5
G37x Loaner
Had my '10 G37 convertible in for service and got a g37x as a loaner. It had a neat feature when you exited the car the seat went back and the steering wheel lifted. Both options could be turned on/off from the settings menu.
Do we not have this convenience available on our verts?
Old Sep 5, 2010 | 06:55 AM
NewGMan's Avatar
NewGMan
Nope. Had this on my 05 Sedan and liked it a lot.
Only way to mimic this is to set your primary (meaning the one your key sets the car for) seat setting to the back position and steering wheel all the way up. Set the other seat setting to your driving position.
Then when you exit hit the button on the door to key position all the way back. When you enter you will have the seats set to the back position and you will need to hit the door button for your driving position to get seats and wheel in position.
The reason for setting your primary settings to the retracted position is so that when you unlock the car with the key fob your seats will be retracted and not go to your normal driving position.
Not totally convenient, but at least gives a way to have similar feature.
Old Sep 5, 2010 | 01:28 PM
da mayor's Avatar
da mayor
only available in the EX/FX/QX/G37 sedan without 6MT
coupes and verts are lleft out
The only option to do it is to set memory setting #2 as to move everything back. All you'll have to do is push the button before you get out of your vert and it'll do the same function (that is if you only use one memory setting)
Old Sep 5, 2010 | 09:04 PM
cvipgo's Avatar
cvipgo
This is exactly I did a year ago "set memory setting #2 as to move everything back. "
Originally Posted by da mayor
only available in the EX/FX/QX/G37 sedan without 6MT coupes and verts are lleft out
sChiG37xS
B4 'n Afta
Nov 6, 2016 06:14 PM
ArmyBoyd
Sep 22, 2015 08:54 AM
dsolis
Sep 17, 2015 11:25 PM
pro-gadgeter
Sep 17, 2015 07:37 PM
IrishMike
Sep 16, 2015 07:07 PM
