FS 2008 Infiniti G35 Sport Sedan 6MT - SoCal
Price: 8500
Clean Title. 2008 Infiniti G35S Sport Sedan 6-speed Manual Transmission Rear Wheel Drive VQ35HR Engine.
Registration is paid and good until June 2021. I will be retaining the personalized license plates, so the car now has new issued license plates by the CA DMV. SMOG is good for 90 days as of May 2, 2020.
Title on hand. No trades.
The car was put back to stock because there was no one buying it with over 10k in mods.
The car will come with the Z1 CSC Elimination Kit, AASCO lightweight flywheel with Exedy Clutch Kit, short throw shifter and Tomei Duracon Shifter that has about 10.5k miles.
Everything works perfectly on the car. Who ever is seriously interested can check out the car if not, please do not waste my time. There are plenty of other Infiniti’s out there that are automatic in the market.
The paint is not that great for being over 10 year old car. The interior is in good condition.
The rear fenders look like bacon due to an emergency fender pull. I had the garage door scratch the rear bumper a year ago. It was repaired and clear coated, but the clear coat started to fade.
The front inner plastic fenders were trimmed to accommodate bigger wheel set ups.
I swapped the the built engine I had before with an engine that has 78k miles. I bought a truck for work and will no longer be driving the Infiniti.
Recently serviced as of posting.
Transmission and differential fluid w/ Redline MT85.
Clutch - Lightweight flywheel, Exedy clutch kit, clutch adjustment, and new clutch (brake) fluid.
Brakes - Fluid Dot4, purged air from lines, new rear brake shoes, new f/r brake pads, resurfaced rotors, brake bed-in.
Oil change w/ Mobile 1 5w-30 w/ new oil filter.
New NGK Spark Plugs gapped to .44.
Flushed and filled new coolant & purged air from system.
Fuel system & OEM injectors cleaned.
New Power steering fluid & purged air from system.
A/C Freon vacuumed and fully recharged.
New window washer fluid.
4-wheel alignment done.
TPMS..
TPMS..
