Got UTEC?
Old May 16, 2006 | 05:54 AM
amg35's Avatar
amg35
Originally Posted by _jb
If you add an MREV2 to a car with the Crawford plenum, isn't that compensating for the lean front cylinders twice?
I remember reading that people were going to try this combination, I just don't remember reading any results or dyno runs.
Exactly why I am considering ECU management and tune. The few that have tried the Crawford/MREV2 have experienced lean AFR's. Plus getting more HP/TQ out of my G is an awesome thing. Thanks.
Old May 16, 2006 | 07:56 AM
Audible Mayhem's Avatar
Audible Mayhem
Performance Factory
its not that hard to learn how to tune it yourself. the tuner PRO is more for a standalone unit for people without the utec.
just get the bosch tuner wideband and the utec. i love it.
Old May 16, 2006 | 11:09 AM
escobar929's Avatar
escobar929
FGC South Florida BOD
so the knock sensor that comes w/ the tuner PRO is not necesary?
Old May 16, 2006 | 01:23 PM
Audible Mayhem
Performance Factory
no the factory knock sensor works just fine. that tuner pro is not limited to any certain type of car. it is a self contained fully functioning wideband/knock light/audible knock sensor unit.
not worth any extra money for what we are using it for
Old May 16, 2006 | 02:29 PM
escobar929's Avatar
escobar929
gotcha, thanks for all the help
Old May 16, 2006 | 03:55 PM
98intrigue's Avatar
98intrigue
Charter Member Florida G35 Club
http://www.my350z.com/forum/showthread.php?t=190142
$900 shipped with MAP sensor.
Old May 16, 2006 | 03:59 PM
WILD121's Avatar
WILD121
Florida G35 Club, General Member
sounds good to me
Old May 17, 2006 | 09:41 PM
amg35's Avatar
amg35
Jeremy, did you consider the Greddy eManage Ultimate? From the description, it appears to be very similar to the UTEC, but is roughly half the cost. Thanks for the input.
Old May 17, 2006 | 10:03 PM
Audible Mayhem
Performance Factory
well you cant raise the rev limiter with the Greddy. i love the greddy. the user interface is soooo much more fun. if you already have a reflash i would do that. the greddy has a target AFR that takes a lot of the work outta tuning also.
here are a couple things that the greddy doesnt have or do....
the utec has knock sensor gaurd that retards the timing if it senses knock. Great safety feature. of course you can set the rev limiter and the utec has a spare solenoid driver.
both great units
Old May 17, 2006 | 10:19 PM
amg35's Avatar
amg35
both great units
Does the greddy do anything to prevent the dreaded knock? If not, sounds like the UTEC is safer or offers more protection of the engine.
Old May 18, 2006 | 06:35 AM
Audible Mayhem
Performance Factory
well the right fuel and timing mixture will prevent the knock... they both do that. what the utec does is when it senses knock it will retard the timing immediately till the knock goes away. this is a safe feature that i really like.
both great units. they both have good points...
Old Jun 22, 2006 | 06:02 PM
Down_Shift's Avatar
Down_Shift
Just got mine today... Anyone have pics on how to install the MAP sensor?
The Utec looks pretty easy plug and play.. The damn thing is HUGE.. How are poeple fitting it under the dash?!
A few other minor things going to be installed this weekend.. then TUNE BABY!
Old Jun 22, 2006 | 09:29 PM
Audible Mayhem
Performance Factory
map sensor is really easy to install, basically just look at it. it has a vacuum line and a plug that plugs into the utec. thats it.
i would take down the stock ecu, take off the bracket that holds the stock ecu. mount the utec to the stock unit, then zip tie it up in the stock location, it works the best. its too big and its even tighter in a G.
good luck, what do you have done to your car??
Old Jun 22, 2006 | 09:34 PM
  #29
Down_Shift's Avatar
Down_Shift
TN Kit
Wastegate relocation kit
Fuji Exhaust
NGK +1 Plugs
Tranny stuff etc
Also have a MD 5/16 spacer I'm going to install with the Utec
Going to start on it tomorrow.. hopefully it doesn't rain.
Old Jun 22, 2006 | 10:24 PM
  #30
Audible Mayhem
Performance Factory
nice man, you have all that installed or you are going to install it, i am about to switch over to being boosted on the utec and will need to figure out some new things, i have NA and N20 down to a science..
