my install
Old Jan 28, 2006 | 02:05 PM
WILD121's Avatar
WILD121
Florida G35 Club, General Member
looks Good Dan... Now if the Lokey meet is boring at least I can watch ScarFace in your Car. LOL
Old Jan 28, 2006 | 02:24 PM
Gumba35's Avatar
Gumba35
Charter Member Florida G35 Club
Nice job Dan.
Old Jan 28, 2006 | 03:36 PM
BlackInfinitiG's Avatar
BlackInfinitiG
it looks like it came out great, look awesome
Old Jan 28, 2006 | 06:42 PM
_jb's Avatar
_jb
Very nice installation, Dan...
It looks super... It looks like it came with the car, which is what you want!!!
Old Jan 28, 2006 | 07:20 PM
aznluder's Avatar
aznluder
Florida G35 Club Premier Member
now you can watch **** while you drive =)
Old Jan 28, 2006 | 07:47 PM
SFLG35's Avatar
SFLG35
FGC Central Florida BOD
Originally Posted by Gilley
Did you install the device to allow use of the steering wheel controls?
no i still need to get one of those.
i also still have to install the sirus tuner that i have as well
then i need to buy the navi unit for it, ipod adapter, and bluetooth adapter.
Old Jan 28, 2006 | 07:48 PM
SFLG35's Avatar
SFLG35
Originally Posted by FL-G35
That is sweeeet, Looks good.
hey i see you live in riverview you should come to one of our tampa meets sometime.
also welcome to the club
SFLG35's Avatar
SFLG35
thanks for all the compliments guys
Old Jan 28, 2006 | 07:58 PM
gwel687's Avatar
gwel687
yea thats really nice and very clean looking...about how long did that take you, and on a scale from 1-10 how hard was it because I am thinking about doing the same thing
Old Jan 28, 2006 | 08:28 PM
BoostedConcepts's Avatar
BoostedConcepts
well it depends
i started about 1130 am time
till about 1215 i drove around tryin to find paint that would match
1245 i had the first layer of primer on
then started taking the buttons off the black controller.
got some lunch, screwed around on the computer.
245 comes primers i dry first layer of paint.
call chuck and findout hes out at the dealership.
315 but second layer of paint on, pick up my room a little but some clothes in the washer.
4 or so chuck arrives after passing my place and having to bust a u turn
we hangout for a bit then head to chillis
about 6 we leave chillis and i head to the mall in downtown to pick up my paycheck
730 i arrive back home, paint somemore and wait for my roommate to leave so i can park in the middle of the garage and take the car apart
bout 8 roommate leaves and i start to work on taking everything apart. i start cruizing right along here, now.
830 i had the old radio out and taken apart.
9 i had the brown buttons off and in the new ac controller, air vents were mounted, new radio mounted.
945 i had the speaker wires soldered together.
10 i was putting it back in and testing. found out i had a bad ground so i had to cut the ground wire and ground it directly to the chassie. then i found out that i only had sound when it was in radio cause the power antenna was connected to the factory remote turn on so i had to cut that and wire it to the remote amp wire.
1030 i was tryin to mount the 6 disc. that took a little while cause its a really tight fit. i had to break off these pins on the back of the glove box so it could slide open and close.
1115 everything was gettin put back together.
midnight i was running the rca cables back to the trunk to hook up to my sub amp. i also ran the fron t and rear cables as well for future use.
110 i was done and car was all put back together.
there was a lot of time in there that i took off and was screwing around in my room or on the computer.
install was not really hard at all. i could have done it in a lot less time if i didnt have to paint and wait for it to dry and then paint somemore. also would have been faster if i didnt take breaks and just done it straight threw.
Old Jan 28, 2006 | 08:33 PM
BoostedConcepts
id give the install about a 2 out of 10 but i know what im doing. ive done a lot of different stereo installs in different cars and have installed a lot of different things on this car.
if you havent ever done anything like this before or if you havent ever taken the dash apart before then this install might be a little more difficult for you, but if you live in florida maybe i can help you when you go to do it.
id say if i had no experiance with this car or stereos id give it about a 6.
i still have to install the sirus tunner that i have as well.
Old Jan 29, 2006 | 07:26 PM
beastie's Avatar
beastie
Dan,
I want one!! Are you able to meet this week. I want to check it out.
Old Jan 29, 2006 | 09:04 PM
SFLG35's Avatar
SFLG35
wednesday we might be able to meet up.
i get out of class at 315 and jason will be down in that area gettin his paint work finished up.
Old Jan 30, 2006 | 12:55 PM
  #29
Omi's Avatar
Omi
From: on some Prius forum somewhere. Also getting 60mpg.
hmmm, that looks surprisingly familiar somehow.....
nice work! Give me a call and I will walk ya through the side pieces for the changer as well.
Old Jan 30, 2006 | 09:45 PM
  #30
SFLG35's Avatar
SFLG35
thanks mike
ill have to hit you up for those side pieces but im thinkin that for the left side ill get some black plastic and put my nitrous switches that and on the left side ill put my nitrous pressure gauge. that way its all hidden and no one can see it.
