My car died coming home from coconut creek!!!!
Old Aug 19, 2007 | 05:55 PM
g35sedan5at's Avatar
g35sedan5at
so im on my way home (kendall) and i get off the turnpike onto 12th street and all of a sudden my car just bogs down completely, no throttle response AT ALL!!! i press the gas, NOTHING. i switch to neutral then drive, NOTHING. so im idling across the street and i finally find a complex and turn in. i park and make a visual inspection, are all my cars parts still there. they are. i turn off the car. i go to turn it back on and it takes a good 5 second to turn on, then 3 seconds. it progressively got back to normal but in park when i blip the gas i hear a very low backfire like noise after i let off the gas. and now the SES light is on!!!! WTF!!!!!
someone help!
Old Aug 19, 2007 | 06:01 PM
express705's Avatar
express705
i have NO clue...
let us know
Old Aug 19, 2007 | 06:10 PM
g35sedan5at
i kinda had that secret fuse a lil loose but i put it back and still. im pretty sure that has nothing to do with it.
Old Aug 19, 2007 | 06:51 PM
g35sedan5at
cmon...someones gotta have an idea. im f-ing pissed right now cuz if its a computer problem or even worse an actual engine problem ima be ****ed and i cant get a loner cuz im not of age.
Old Aug 19, 2007 | 07:05 PM
r10apple's Avatar
r10apple
I think I had the same problem: let's see. If you floor the car, in park or neutral or in gear, it won't go over about 1200 rpms at all. Therefore, it won't even shift into second gear and will never go more than about 10mph. If that is you, I had the exact same problem, and Infiniti says it was because of my gas cap being loose. This didn't make sense to me because I drove over 100 miles since I had filled up and started and turned the car off and on twice, but that was teh explanation I had. Either way, they had to tow my car in and reset everything--all under warranty. Hope this helps...
Old Aug 19, 2007 | 07:07 PM
g35sedan5at
ill see. thanx
Old Aug 19, 2007 | 07:10 PM
BigShow's Avatar
BigShow
you can get a loaner bro...just get someone old enough to sign for you
Old Aug 19, 2007 | 07:26 PM
GreenGoblin's Avatar
GreenGoblin
sfl g club president
try an ecu reset unhook the neg battery terminal overnight
Old Aug 19, 2007 | 07:29 PM
g35sedan5at
i was thinkin about that but im a little girl when it comes to my seat position and i have it all on memory and connected to my intell key so when i get in my seat moves by itself...lol.
Old Aug 19, 2007 | 07:36 PM
oneshot's Avatar
oneshot
broken car or having to re-enter your seat position....it's a fairly easy choice.
Old Aug 19, 2007 | 07:38 PM
GreenGoblin
ya exactly
Old Aug 19, 2007 | 07:44 PM
g35sedan5at
damn, i just got ownd from oneshot....lol. on my way to disconnect battery now with head inbetween legs.
g35sedan5at
btw, mike i see ur on the thread right now. i called u but no answer... ): lol.
Old Aug 19, 2007 | 07:50 PM
GreenGoblin
lol good choice
Old Aug 19, 2007 | 08:08 PM
rpm06g35's Avatar
rpm06g35
sorry bro phone was off call back if ya want sounds like a vac leak or some wierd bug let me know late mike
