MREV2 + Motordyne 5/16"! What a combo!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 18, 2007 | 09:42 AM
g35sedan5at's Avatar
g35sedan5at
i run my JWT popcharger with no heatshield and not connected to the long black thing that acts as a guide for air through the grill and it most def pulls harder. and i can assure that i have hotter weather than most of u on this forum.lol. every said no heatsheild id lose power but it doesnt seem so.
Old Aug 18, 2007 | 11:56 AM
Hydrazine's Avatar
Hydrazine
Journeyman
I tested the effect of hot to cold air ingestion on the dyno and it made a big difference.
Using a trash can full of ice cubes and a nework of dryer ducting I was able to supply the intake with cold air at about 45' F. By mixing the cold air and with hot air from behind the radiator I was able to vary the mixture to vary the air temperature from ~ 50'F to 120'F.
I tested from lowest to highest in 10' F increments to see the effect on the power curve. And it really made a big difference. 10-15 HP across most of the curve.
Also note, at low temperatures the car ran leaner than normal and at high temperatures it began to run rich.
Old Aug 18, 2007 | 02:25 PM
NISMOG350GT's Avatar
NISMOG350GT
Whats traction?
Originally Posted by battlebuddyP
the rev up how do you know if ur engine is the rev up im not sure?
2005 and up - Rev-up
Old Aug 18, 2007 | 02:40 PM
highroller087's Avatar
highroller087
i'm thinking about putting MOTORDYNE ISO THERMAL 5/16 PLENUM SPACER KIT into my G35 Coupe 5AT.. should I also put my stock intake back? I have a Stillen w/ Z Tube
and also i've heard its waste of money if I put MREV2 on??
Old Aug 18, 2007 | 04:56 PM
battlebuddyP's Avatar
battlebuddyP
how old is your stillen and z tube miles... if u switch back out how much would u take for it wat all do u have still??
Old Aug 19, 2007 | 01:19 AM
Hydrazine's Avatar
Hydrazine
Journeyman
No, not at all. The Stillen well works well with the MREV2.
Keep your Stillen.
Old Aug 19, 2007 | 09:41 AM
Ramon's Avatar
Ramon
Originally Posted by Hydrazine
I've tested several of the long tube CAI's on the dyno and they lose power every time.
And its not just with a spacer. They lose about 3+HP no matter what you hook them up to.
I see! Now, let's say I get rid of my CAI and get a Z-tube with a K&N filter. Although I was losing about 3+HP as you have mentioned, will I be able to tell the difference in gains with the Z-tube once I start driving the car? Is it that noticeable where people can really say "My car does feel faster!".
I'm EXTREMELY happy with the MREV2 + Spacer. But if you tell me that they will work much better if I get rid of my CAI, then I probably will get a Z-tube and K&N filter. Thank you in advance.
Old Aug 19, 2007 | 07:31 PM
Hydrazine's Avatar
Hydrazine
Journeyman
You know what.... I've never dynod a K&N intake.
I say take it to Performance Factory and get a baseline dyno. Remove the long tube CAI and dyno it again without removing the car from the dyno.
Then post you results here.
A lot of people would like to see your results.
ZSpeedPerformance
Drivetrain
12
Sep 9, 2016 11:20 AM
OneSickBlackG
Jan 6, 2016 08:49 AM
Rayramg37
Nov 18, 2015 09:06 AM
Wreckreation
Sep 21, 2015 06:27 PM
Amrit.bhathal
Sep 11, 2015 07:36 PM
