camber and toe help!!
Old Aug 4, 2007 | 11:55 AM
RaFmAn123's Avatar
RaFmAn123
hey guys i need some help i lowered my car with the tein basics adjustables and i installed the spc camber kit in the rear and went to tuffy to get and alignment they did it and said it was good i dont know what i did with the print out but when i drive i can see black stuff on the bumper and the tires are hot. i took it back and they said they fixed it but its the same with the black stuff.
i dont have the camber kit in the front can that be a problem?? i want to drive the car but i dont want to buy tires every couple of months.
does anyone know somewhere in orlando i can take it to fix it???
also for the front can i just get the camber kit or do i need camber and toe its so damn expensive.
Old Aug 4, 2007 | 02:09 PM
SFLG35's Avatar
SFLG35
FGC Central Florida BOD
hmm
not sure but if you are seeing rubber on the rear bumper it sounds to me like your toe is way off aka too much toe in. cant really tell from the pics though. do you have a full on rear shot? also how about one that is looking down from the top of the fender?
98intrigue's Avatar
98intrigue
Charter Member Florida G35 Club
Nice color....but the offsets on those wheels are horrible. Get some spacers.
Old Aug 4, 2007 | 02:46 PM
Gilley's Avatar
Gilley
Florida G35 Club, General Member
So you installed the rear camber arms but no toe bolts? The toe bolts are inexpensive and fairly easy to install with a Dremel. Do that and take it to Tires Way on East Colonial (east of Semoran) or TredAlign on John Young Parkway.
It looks like you do need a front camber kit, which are adjustable a-arms. In front, toe is not adjusted by the a-arms.
You have to pay the price to lower a car correctly.
Old Aug 4, 2007 | 03:05 PM
RaFmAn123's Avatar
RaFmAn123
in the rear i have the camber arm and the toe bolt i used my dremel and but the oval hole for the bolt to slide side to side and then i took it for alignment but i still dont feel comfortable about the black stuff it def tire.
Old Aug 4, 2007 | 05:51 PM
GreenGoblin's Avatar
GreenGoblin
sfl g club president
so is the tire rubbing
Old Aug 4, 2007 | 05:55 PM
w0ady's Avatar
w0ady
+1. if you show us exactly where the tire is rubbing, we might have a better idea of what the problem is.
Old Aug 4, 2007 | 09:25 PM
Gilley's Avatar
Gilley
Since the toe bolts are installed, either your alignment shop doesn't know what they are doing or something else is wrong. Tires do get hot sometimes. it is over 90 degrees outside and the asphalt is hotter.
Pics of the specific problem would be good.
Old Aug 5, 2007 | 12:25 AM
RaFmAn123's Avatar
RaFmAn123
theres no rubbing guys its the alignment i will take better pics tommorow
in the front can i get away with just getting a camber kit or do i need toe for the front too.
Old Aug 5, 2007 | 04:22 PM
Gilley's Avatar
Gilley
Up front, the toe is adjustable with what is already there. There is no toe kit for the front. You ony need the a-arms.
Kojack
Oct 9, 2015 05:53 PM
Allboutcali
Sep 26, 2015 03:43 PM
jfisher
Sep 9, 2015 04:17 PM
jfisher
Sep 8, 2015 04:16 PM
