2003 G35 Coupe Driver's side Window not working...*HELP!*
Old Jun 19, 2007 | 05:45 PM
*BlackG35Coupe*'s Avatar
*BlackG35Coupe*
Hey guys,
A couple days ago my driver's side window stopped working, it wouldn't go down, so I kept playing with it and finally it did. Now it won't go back up! When I press the button I just hear a clicking noise. Has anyone had this problem before? I did some research and found this is pretty common for our cars for the window motor to crap out, but I'm just over the warranty period so I'm screwed Also, if anyone knows where to get cheap parts and labor for the fix I'd appreciate it. My passenger side window still works fine btw. Thanks in advance!
Old Jun 19, 2007 | 10:34 PM
Gilley's Avatar
Gilley
Florida G35 Club, General Member
If you are just over the warranty, the stealership may fix it under warranty under good will. It is a very common and known problem.
Start by calling Infiniti Consumer Assistance anonymously and see what they say. They may give the green light and instruct the dealer to fix it.
Old Jun 20, 2007 | 01:01 AM
nghiars's Avatar
nghiars
crappy motor... works better in cold weather too.. replaced my passenger under warranty
Old Jun 20, 2007 | 03:43 AM
2slo2bfurious's Avatar
2slo2bfurious
You window motor/regulator is going out, in the meantime before you get it fixed. Try this, shut the down a little harder than normal and hold the window switch in the up or down pos. while closing. It makes the window work temp. to get it up or down.
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
joeposter
Sep 8, 2015 04:36 PM
pcwd
Aug 12, 2015 06:54 PM
