How Much For Brakes?
Old Feb 7, 2007 | 01:12 PM
WILD121's Avatar
WILD121
Florida G35 Club, General Member
I just got newe rotors, going to get new pads and lines while im at it. waiting on the rotors still and too lazy to go online and find the best deal for pads and lines.
Old Feb 7, 2007 | 01:20 PM
Gilley's Avatar
Gilley
www.importrp.com
Old Feb 7, 2007 | 01:37 PM
2slo2bfurious's Avatar
2slo2bfurious
Anyone know a cheap replacement for the 03-04 brembos? I think I'm almost ready for mine..... I replaced them once with hawks, just wondering what else has come out since then......
Old Feb 7, 2007 | 02:47 PM
Gilley's Avatar
Gilley
For pads, the Axxis are a great pad at a great price. I got them at www.importrp.com, which is why I suggested it to Shermie.
Old Feb 7, 2007 | 03:47 PM
Texasscout's Avatar
Texasscout
Be Prepaired
I don't know if you saw my posts on the 05' pad wear, but I had 42,000 on mine and had less than 2mm of wear on them. They looked almost new.
I was running in the Raging Bull run, so I changed the pads and flushed the fluid anyway. I used ECB "Green Stuff" pads front and back. I didn't need to turn the rotors, they looked like you just pulled them out of the box. The pads come with a "break-in" compound on them that will take off any glaze that is left from the old pads. They stop even better now than when new. (Follow the "bed-in" process)
Just because you feel a vibration does not mean that you have warped rotors (see StopTech's website, white papers), you may just have some pad material impregnated into the rotors giving that grab as you go past it.
I also found that you can't remove the back rotors without a puller. If you have never done ANY kind of work like this, DON'T! Your life depends on it. My dealer quoted $200 per axle to do it.
Old Feb 7, 2007 | 04:15 PM
Gilley's Avatar
Gilley
I removed my rear rotors (and a friend's) without a puller. I used a rubber mallot and hit it from the back side. It takes a little work, but it's off in less than 5 minutes. It's no different than pulling the front rotors.
Old Feb 7, 2007 | 04:23 PM
98intrigue's Avatar
98intrigue
Charter Member Florida G35 Club
I bought Brembo slotted rotors and Project Mu NS pads from irparts.com. Best prices available on the net.
Kojack
Oct 9, 2015 05:53 PM
Mattimus
Oct 4, 2015 01:33 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
