KPTechnologies Module Sale
FGC Central Florida BOD
Shift Lights - $67.26
1 - White
1 - Green
1 - Red
2 - Amber
Product Description:
The shift light module is easily programmed by revving the engine to half the desired RPM and then pressing the button. Once the shift point is set, the included 3mm SUPER BRIGHT LED indicator will ensure precise shifts every time (for best results, it is recommended to install the LED through a small, eye-level hole in the A-pillar and to use an existing traction control button as the switch).
Additional Features:
*No RPM switches or dial indicators used for programming
Vehicle Compatibility:
All vehicle makes and models.
Sunroof Controllers - $87.86 - 7
The Sunroof module makes it possible to vent, open, and close the sunroof remotely by using the factory key FOB. Mounted under the driver side dash, this module allows users to easily vent (can be programmed to open) the sunroof by sequentially pressing the ‘LOCK/UNLOCK’ button. Pressing the ‘LOCK’ button twice will close the sunroof. Once installed, the sunroof operates as normal.
*The module integrates flawlessly with the OEM remote window down feature AND the KPtechnologies Window Roll-up module.
Infiniti G35 Coupe ONLY (’03-up), Module does NOT work on Sedan models.
Switch Memory Modules - $33.27 - 5
The traction control module is used to add a memory feature to the traction control switch in your vehicle. The unit automatically stores the ON/OFF state of the switch when the vehicle is shut off and restores the setting when the ignition is turned on.
*Fully compatible with ANY push button switch in the vehicle, module not limited to the traction control system.
All vehicle makes and models equipped with a Traction Control System and including a push-button switch.
paypal is sales'at'boostedconcepts.com
replace 'at' with @
can ship as soon as payment is made
thanks
1 - White
1 - Green
1 - Red
2 - Amber
replace 'at' with @
thanks
Blue_Batmobile
Interior/Exterior Items
Sep 4, 2015 11:45 PM
Sylo
Sep 3, 2015 08:27 PM
