DIY: G37 all headlight bulb replacement
Old Jul 11, 2008 | 10:34 AM
VIP G's Avatar
VIP G
For everyone who has had a hard time or is confused about changing their headlight bulbs this is for you.
Today I wanted to check if I could remove my fog lights so I could change the bulbs. (the answer is yes) While I was at it I took so pictures and circled what is what.
These are the sizes needed:
HID: D2S
Fog: H1
Parking: 194
Here we go:
1. Loosen lug nuts on a front tire (I started with the left front one)
2. Jack car up and remove lug nuts and tire
3. pop out the three plastic clips on the wheel well so it can be folded behind the brake. after that you will see this once you look in their
Circled in red is the HID, Blue is the fog light, and Yellow is your parking lights
4. next step is to removed the covers of the HID's and the fogs, just twist left and they should pop off and will look like this
Note: carefully with the fog cover because wires run through it, so don't rip them out.
Now for each of the three bulbs its a little different:
HID's
- twist HID connection to the left (circled in purple)
After this you will need to remove the screw using a small phillipshead. After that the light should come out easily.
Note: Be careful because the oil from your fingers will damage the bulb, so don't touch it :tut
Then insert new bulb and do the steps in reverse
Fogs:
- Unscrew the 2 screws using a small phillipshead. Bulb should easily come out. You can leave the wiring connected so it won't be a pain to reconnect the wire after you put it back in. (fogs are circled in blue)
Insert new bulb then reverse the steps
Parking:
-This is the toughest to get to because the area is so tight. A long black plastic piece sticks out, so take that and twist to the left. Your bulb and will come out with it. (The area is circled in yellow)
Now insert new bulb and do the steps in reverse.
There you go everyone! Hope this makes things easier and if you have questions e-mail me. CYO44Baseball32@aol.com
Please sticky this!!!
Insert new bulb :ninja2
File Type: jpg
File Type: jpg
Old Jul 11, 2008 | 01:16 PM
PSYH's Avatar
PSYH
Post Whore
Thanks, VIP!
I guess I'll try this way...
Just one more thing: should I disconnect the car battery so I don't accidentally short out something or electrocute myself??
Old Jul 12, 2008 | 12:53 AM
VIP G's Avatar
VIP G
nah you'll be ok, I never did and I've done this a bunch of times
Old Jul 12, 2008 | 02:17 AM
xeddyboi420x's Avatar
xeddyboi420x
Thanks!
Old Jul 19, 2008 | 02:48 AM
Andyrox's Avatar
Andyrox
NIICe this is very useful, however, can you post all the bulb sizes.
Old Jul 19, 2008 | 11:39 AM
sumo8me's Avatar
sumo8me
i never unscrewed anything. should just be clips. just push down and unlatch
Old Jul 19, 2008 | 11:52 AM
J.Oh's Avatar
J.Oh
search the forum for that but i believe the fog is an h2 and i know the city is a 194/168
Old Jul 19, 2008 | 11:53 AM
VIP G's Avatar
VIP G
Ok sure,
HID: D2S
Fog: H1
Parking: 194
Old Jul 19, 2008 | 12:17 PM
J.Oh's Avatar
J.Oh
i was close...
Old Jul 19, 2008 | 12:39 PM
gan78mao's Avatar
gan78mao
great write up!
Old Jul 19, 2008 | 06:50 PM
aznutx's Avatar
aznutx
awesome write up
Old Jul 19, 2008 | 11:07 PM
myk1013's Avatar
myk1013
THANK YOU!!
Could you point out which plastic clips exactly to remove to fold the wheel well lining.
Old Jul 20, 2008 | 10:31 AM
VIP G's Avatar
VIP G
I dont got a pic of that right now, but if you remove the wheel you'll see those plastic pop clips. One is on top looking straight up other is right in front of you looking right at it, and the other is to your left looking straight at it.
Old Aug 8, 2008 | 05:53 PM
CtK's Avatar
CtK
holy junk!!!! that was hard as hell!! i dont have the huge hands and it was very difficult to get the fog lights out, especially on the passenger side.
Enough venting, cant wait to see what they look like at night.
thanks
Old Aug 11, 2008 | 11:47 AM
msb3079's Avatar
msb3079
thanks for the DIY...
putting in 6K McCulloghs tonite or tomorrow...
install looks pretty much the same as the 35 was.
