Doug's ambient lighting mod
Old May 14, 2008 | 03:41 AM
ucla bruin's Avatar
ucla bruin
A continuation from......
https://www.myg37.com/forums/showthr...71#post2333971
This is a supplement to Doug's write-up because I am lazy and don't want to include the details . Pics should speak for themselves.....
Materials:
18-20 gauge filament-core (soft-core?) wires (I used solid-core, it works too but just harder to deal with)
LEDs specified in Doug's DIY write-up
Potentiometer
Switch
Tools:
Screw driver
Drill
Wire stripper
Soldering iron+solder
First grab the center console that surrounds the shifter at the rear most part and pull upward towards the ceiling:
Exposed (if you want to change the ****...)
Disconnect the power
Go back in the house and make one of these
No, I mean one of these
You might want to measure the length of the wire before you cut it, but give yourself some slack so it's easier to install.
Pics of random steps
Take the whole thing that you've just made back out to the car but BE CAREFUL that the solder joints on the LEDs are not tugging in different directions because it might tear
Instead of soldering to the yellow cigarette trim light wire for power, I just stripped away a section of it and wrapped my solid-core wire around it then taped it up with electrical tape. (for a less-permanent set-up)
Feed the passenger side LEDs through the center
Feed everything else (driver side LED, potentiometer, switch) to the left side
Drill your holes for the potentiometer and switch mounting locations then secure them. Mount the LEDs and connect the grounds.
Results
https://www.myg37.com/forums/showthr...73#post2333973
DOMODOMO
__________________
Old May 14, 2008 | 12:01 PM
xeddyboi420x's Avatar
xeddyboi420x
and how many cups of flour for the cake part?
Old May 14, 2008 | 12:09 PM
ucla bruin's Avatar
ucla bruin
Haha
__________________
Old May 14, 2008 | 12:17 PM
gan78mao's Avatar
gan78mao
great write up!!!
Old May 14, 2008 | 12:27 PM
vINCe_Inc's Avatar
vINCe_Inc
those led's have built in resistors to take on the full 12 volts ?
Old May 14, 2008 | 12:52 PM
ucla bruin's Avatar
ucla bruin
The LEDs are on a strip, which has resistors.
__________________
Old May 14, 2008 | 01:06 PM
B L U E S L A T E's Avatar
B L U E S L A T E
You wanna help me do this, too?
Old May 14, 2008 | 02:44 PM
ucla bruin's Avatar
ucla bruin
Alright, should be the same wire for the sedan, not sure though.
__________________
Old May 14, 2008 | 02:47 PM
B L U E S L A T E
They probably are the same. Well, I got the service manual we can take a look at it, too.
bboysteele's Avatar
bboysteele
Originally Posted by gan78mao
great write up!!!
Or actually great post up! Come on Bruin, make a write up.
Old May 14, 2008 | 03:10 PM
ucla bruin's Avatar
ucla bruin
Sounds good.
Wha? What's the difference? more details?
__________________
Old May 16, 2008 | 09:44 PM
jay.diem's Avatar
jay.diem
cool nice write up... thanks for good pix
Old May 18, 2008 | 07:53 PM
]\[ /-\ ]\/['s Avatar
so these lights only come on when the car is on and u have the switch 'ON"?
or do they come on when you open the door? like the accent lights
Old May 18, 2008 | 08:59 PM
Dieseldoug22's Avatar
Dieseldoug22
They come on with the headlights. They are hard to see in the day, and it looks great while driving... that is why it is not hooked up to the door.
Great write up Danny.
Old May 18, 2008 | 09:04 PM
ucla bruin's Avatar
ucla bruin
Thanks, couldn't have done it without your help!
The switch in the circuit layout is only to switch between blue or white LEDs.
__________________
