Special TUNERZ STORE | Berk Technology 370Z/G37 High Flow Cats & Test Pipes
Parts Specialist
Part# BT1407-HFC-MET
Metallic substrate spun catalytic converters, OBDII & 49 state compliant. Full stainless steel construction. Metallic substrate offers higher flow and lighter weight. Uses advanced spiral wound ultra thin foil. Includes our custom made soft crush graphite collector gaskets for a leak free seal. These are made specifically for the new HR motor by BERK. Made with pride in the USA. As of January 1st, 2009, performance high flow cats are intended for off-road use only in the state of California.
2009-up 370Z
2007-2008 350Z
2008-up G37 Coupe
2007-up G35 Sedan
Part# BT1407
Our highly anticipated 2007-up test pipes are now available! Features fully gusseted and plated support brackets, the strongest in the industry. Includes the same leak free soft crush graphite collector gaskets found in our 07- up HFC's. Mechanical CEL fix included, but on the 07-up HR motors it is less effective than the 03-06 motors.
2009-up 370Z
2007-2008 350Z
2008-up G37 Coupe
2007-up G35 Sedan
Please PM me for pricing structure!!
