Vendor ZSP G35 / G37 Heavy Duty CSC Concentric Slave Cylinder 07+ Sedan, 08+ Coupe
Old Jul 11, 2012 | 03:55 PM
Coz@Czp's Avatar
Coz@Czp
The kits come complete with everything you need to install, No other parts are needed other than a couple jars of FRESH SEALED CONTAINERS of Dot 3/4 brake fluid.
It will be necessary to modify the front cover of the transmission slightly in order to fit the bigger, heavier duty slave cylinder into the transmission housing. This takes about 10 minutes and is pretty simple to do. All instructions are included with the kit or will be e-mailed to you in PDF format.
The ZSpeed heavy duty slave cylinder kit features all metal/aluminum construction, Floating internal seal (better than stationary that is used in the OEM Slave) All stainless fluid hoses that delete the stock rubber hose by your exhaust.
Old Jul 20, 2012 | 12:40 PM
Coz@Czp's Avatar
Coz@Czp
Thread Bump
Old Feb 1, 2016 | 03:34 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Apr 4, 2016 | 03:30 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old May 5, 2016 | 03:04 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Jun 1, 2016 | 04:01 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Jun 30, 2016 | 03:52 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Sep 26, 2016 | 01:17 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Oct 19, 2016 | 01:06 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Nov 16, 2016 | 11:19 AM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Nov 28, 2016 | 12:35 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Dec 16, 2016 | 04:28 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Jan 11, 2017 | 06:23 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Feb 6, 2017 | 06:12 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Mar 3, 2017 | 05:21 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
