Engine, Intake and Exhaust Subforum dedicated to breather or engine mods (intakes, exhaust, pulleys, N/A mods etc.)
Stillen Grounding Kit
Old Jul 8, 2021 | 07:37 PM
woodieg37's Avatar
woodieg37
Are they worth it? Seen alot of engine bays with the Throttlebody ground kit. Im allways down for improving my car. Does it or just for looks ? I mean 100$
Old Jul 9, 2021 | 10:40 AM
BULL's Avatar
BULL
Moderador
Save your money, these cars come equipped with a toggling regulator controlled by the IPDM that switches it's charging load based off on the needed events.
There is a battery current sensor located in the negative battery cable that monitors charge/discharge and helps this toggling of voltage.
With that being said, an upgrade would be a new negative battery cable and route it like factory.
The other two grounds located in the timing cover are pretty thick themselves and can handle the job required.
You can test the resistance of your ground wires which there shouldn't be any. If there is then a replacement would help a bit.
Sometimes these ground kits bypass the sensor and tell the ECM to slow down the engagement of the regulator which will cause lower voltages and for some battery drains.
Old Mar 19, 2022 | 08:03 PM
spoolin03's Avatar
spoolin03
Do you mean a new negative battery cable, same gauge thickness as OEM, without the IPDM sensor?
Old Mar 19, 2022 | 08:09 PM
spoolin03's Avatar
spoolin03
I meant the small extra dongle on the positive part of the battery, not IPDM
Old Mar 19, 2022 | 08:44 PM
BULL's Avatar
BULL
Moderador
A new wire with sensor (oem)
a new thicker wire passed through the sensor.
ChefMatt
Dec 13, 2020 12:30 PM
Eyeshield25
Jul 27, 2017 12:18 AM
CasperG37
Aug 4, 2015 02:10 PM
LAG37
MODDING 411
30
Jun 4, 2008 01:28 PM
