Stillen Crankshaft Pulley
I recently had this installed when my car was in for warranty work and they had the drive belt off anyway. So I cannot comment on the exact install, but I would imagine it is fairly straight forward as I have installed pulleys on other cars before.
As I expected, there is not a huge gain in performance. However, there is a nice improvement in throttle response. It revs much quicker now. I always thought this engine was very slow to respond to throttle inputs. That is now much improved.
I would not make this your first mod. But it is a good improvement considering the relatively low cost. Definitely worth doing if you are already replacing the drive belt.
So oem 17 inch rims are 27ish lbs
all seasons I was running 27lbs
= 55 lbs with lug nuts
17 inch Rpf1 are 15ish lbs (12 ish lbs lighter)
Pilot sport 3+ tires 23lbs (4lbs lighter)
Lugs (.5lb lighter each corner)
= 39 ish lbs with lug nuts
Sorry for delay, just saw your post.
