P0021 and p0524 codes
Old Apr 9, 2024 | 06:55 PM
Ethan_D's Avatar
Ethan_D
I got a low oil pressure and camshaft position timing over advanced codes about 2 weeks ago I changed the oil and oil filter and cleared the codes and it ran well for about 2 days then the same problem came back. While driving it would get up to around 2500 3k rpm and cut power. From what I've looked into I think it could be the gallery gasket but if anyone has any other ideas or answers it would be helpful
Old Apr 10, 2024 | 07:05 AM
projectpanda13's Avatar
projectpanda13
I would confirm oil pressure by testing it and also test the VTC solenoid on bank2. You can test to to check if the valves are opening when voltage is applied.
tripled
Sep 18, 2022 06:40 AM
jackrieger0
May 2, 2022 04:20 PM
