Help Intermittent Start
Old Apr 8, 2024 | 12:22 AM
TyjuanG37x's Avatar
TyjuanG37x
Intermittent Start
Just purchased a 2011 Infiniti G37x AWD with 88k miles. It’s starting to have intermittent start issues. ( I press the start button while holding the brakes, car lights up as usual, no error codes, but wont start) no noise from engine bay, just the normal beeps.
What I’ve done/ checked:
It has a new battery, I cleaned the battery terminals, I put in a new key fob battery, I checked and cleaned the brake switch also.
No error codes on OBD2 or engine lights.
The IPDM didn’t seem to have any issues upon taking it out and inspecting it visually.
Old Apr 9, 2024 | 12:45 PM
TyjuanG37x's Avatar
TyjuanG37x
Update
Checked the BCM board, looks pristine inside and out, all connectors look good, cleaned the ground terminal that was directly under it since it had a little corrosion, cleaned the power cable end the the starter, I have the battery on a tester/charger.
if all this fails I’m gonna try tapping the starter solenoid while the tires off and run to try to start it while I have the access to it
Old Apr 10, 2024 | 08:08 AM
TyjuanG37x's Avatar
TyjuanG37x
Update part 2
I jumped the pin 80 wire to the starter and the car crunk up fine,
chitty
May 6, 2025 09:04 PM
Lee Nguyen
Nov 21, 2019 08:32 PM
STEAMROLL9
Dec 4, 2012 08:21 PM
asitag
Aug 23, 2011 08:20 PM
G2Envy
14
Feb 23, 2008 05:56 PM
