Flex Plate replacement Z1 or OEM
Old Jan 28, 2024 | 02:12 PM
Josh South's Avatar
Josh South
Hello all, I have had a rattle/chatter coming from the transmission at idle and low rpms while in drive and reverse. I have narrowed it down to a cracked flexplate. Z1 sells a billet aluminum lighter flex plate for $499 and an OEM one for around $463. I wonder if it is worth it to go with the lighter flexplate or just stick to OEM. I am usually an OEM guy but the price is very similar and having a lighter flexplate sounds cool if I'm already going to be in there. Can anyone chime in and give me a recommendation?
Old Jan 28, 2024 | 07:34 PM
SkysG37's Avatar
SkysG37
I'd stick with OEM unless you have a power adder or at least a shift kit and like using the paddles.
Also, double check they have it in stock before you buy.
Z1 is notorious for long waits on out of stock items.
JuniorG
Sep 8, 2023 03:47 PM
14Q60awdSPORT
Apr 24, 2023 11:55 AM
Krzysztof47
Aug 11, 2022 10:29 AM
PattyP
Feb 24, 2022 07:55 AM
HarvirK
Jul 9, 2019 02:06 AM
