Tuner - torque and traction control
Old Jun 21, 2022 | 12:16 PM
slickman13's Avatar
slickman13
Is there a tuner that will disable torque and traction control ? I have a 2013 g37 Auto.
Old Jun 22, 2022 | 08:23 AM
BULL's Avatar
BULL
Moderador
What is the goal you're trying to achieve?
Old Jun 22, 2022 | 09:33 AM
slickman13's Avatar
slickman13
i want to disable disable both, i don’t like not being in full control. for example, i pull out i to traffics with my foot to the e floor and the system goes into torque limit and is low down. not safe.
Old Jun 22, 2022 | 09:47 AM
BULL's Avatar
BULL
Moderador
Weird, a simple toggle of the VDC should take care of this issue.
In a 7AT disabling full traction will have you one wheel peeling since the ABS system helps control the faster spinning wheel.
A tune will essentially give you better/faster throttle opening rates however unless your vehicle has a proper LSD it will just smoke one tire with trac off.
My vehicle is flashed, 7AT with intakes. I've installed a traction control delete button that I've made and with the switch on the car is trash off the line vs just VDC off, trac on.
You will never be able to outperform the OEM systems traction control, the only reasons these should be deleted are for high torque, mechanical LSD, sticky tire cars that need a bit of slip out the line.
Old Jun 23, 2022 | 01:33 PM
rotarymike's Avatar
rotarymike
Moderator in Moderation
Sounds like he needs stickier tires to help him hook up. Otherwise - push the VDC defeat button when you start the car.
Rawebby
Feb 7, 2022 10:05 AM
onthefence
May 31, 2019 10:55 AM
bobtaz13
Oct 11, 2015 12:58 PM
xzil3d
Apr 18, 2008 06:01 PM
