2010 G37s Have Power, No Crank, No Click, No ODB2, ABS U1000
Edit: Sorry about the title, it should be limited ODB2
This adventure started with a head unit replacement. Owner got the wrong radio so ended up just putting everything back together. At that point the car wouldn't respond when the start button was pressed, just displayed Lock.
After searching, I found out that this was a Steering Lock Issue so I replaced the steering lock module, was able to power on the car and removed the steering lock fuse.
At this point the car turns on but doesn't crank. When I push the ignition button I get lights on the instrument cluster, solid red security symbol and the engine cooling fans turn on. Nothing else happens. There is no clicking like some people have suggested.
I am also not able to get a full connection to ODB2, I can scan ABS and get U1000, nothing else.
I saw a video on youtube of someone having the exact same problem and they said they replaced the IPDM, so I replaced that also. Still the same problem.
I replaced fuse #6 and also charged the battery.
Any ideas?
Any ideas?
Did you/ installer/ whomever, use the same AC Amplifier (white, plastic, rectangular box mounted on the headunit) that came with the car? Or was that mixed up as well? Did they verify that the connectors were reinstalled in their correct location? Specifically, there are two (2) connectors behind that center stack that can easily get crossed. Look for two (2) connectors that are wrapped in yellow tape. Make sure these two are plugged into the aforementioned AC Amp.
Were all fuses checked?
I checked most fuses that would be pertinent to the car at least cranking.
Do you know if installing the new steering lock module if the keys now require reprogramming?
If all you replaced was the ESCL (Steering Lock) then no programming is needed. Being that the engine started indicates that IVIS (immobilizer) was not triggered. If the car doors lock/unlock with the fob, then everything is good to go.
No thanks needed. Just "pay it forward." The blessing is that, in this case, it was a easy fix.
Interesting. There is nothing anywhere that indicates programming of the ESCL. You are talking about the module underneath the dash/ steering column and not the key slot?
Either way, I would strongly suggest that you plug the "old" ESCL back in. Start the engine, and with the engine running either pull the steering lock fuse or cut the brown wire at the lock itself. This car is a 2010 and falls into the range of potential ESCL failures which leaves the car dead as a door nail. Disabling the module- with the engine running- ensures that this common AND expensive issue does not occur.
m3clubracer (01-16-2023)
I indeed pulled the fuse while the engine was running, but the new ESCL is in locked mode and the car won't recognize the key to start the car to put it in unlocked mode. It's a paradox right now.
Key programming is between the fob and the BCM.
New ESCL- did you put fuse back in? See if it "unlocks?" Why not just remove it completely?
If the car is running normally with the old ESCL, and the fuse has been pulled thereby keeping it "unlocked," I'd leave well enough alone. Unless I'm missing something...(?).
The old ESCL is not installed and in this model I have to tear down the whole dash and drop the steering column to remove it. Which I don't really want to do again. haha
I may just try reprogramming the keys. The few videos I've seen of the reprogramming of the car don't mention anything about unlocked steering wheel, it doesn't even really make sense, because a key is required to unlock the steering.
Personally, I'd just plug the old ESCL back in and tuck it up under the dash somewhere. It does not have to be bolted to the column. Might be considered "tacky" but it's effective.
Programming keys can be hit or miss. Just remember you need to have ALL keys present before starting the procedure.
Good luck and please update on the final outcome.
I am having the same issue.
I did not replace anything at all on the vehicle. It was driving one day. Then the next it would just click once sounds like the starter solenoid and that’s it. Not clicking like a dead battery or cranking of any kind
SonicVQ
04-14-2021 11:09 PM
nytxelk
11-18-2019 08:31 AM
