View Poll Results: How much inches I need to cut the driveshaft from my g35
Cut my driveshaft from my g35 coup ?
0%
Or look for a g37 2015 sedan driveshaft ?
0%
How much inches I have to cut my g35 2005 driveshaft
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Help 2005 g35 Transmission swap to a g37 2015 transmission are the drive shift same
Old Jan 31, 2022 | 01:59 AM
Emoneyg35's Avatar
Emoneyg35
I have a G 35 2005coupe with a G 37 2015 transmission and the driveshaft don’t fit !!!should I cut the drive shaft or should ??? Or look for the G 37 Sedan driveshaft.?? Or coup one ??
Old Feb 2, 2022 | 08:27 AM
projectpanda13's Avatar
projectpanda13
I would feel that the G37 sedan driveshaft may not fit also. the length might be a new length because the chassis of your g35 coupe is much different than a g37 sedan, then the length of the transmission originally from both cars are different.
you may need to measure the distance and get a shop to advise you
Old Feb 2, 2022 | 09:57 AM
BULL's Avatar
BULL
Moderador
Just asking questions:
Is this research you came up on?
Recommended by a buddy or something you read that it would work?
Was it just a trans swap or did you went ahead and swapped any electronics?
Reason why I ask is that the 7AT trans is quite the pesky one, I would see this swap to be somewhat achievable in 2008+ G35s since they share the same body but not with the V35 G35.
I guess you really cant tell any functions right now without the driveshaft but I'm curious as this would be a first for me.
RA081224
Dec 13, 2021 11:26 PM
Dandroid
Nov 1, 2017 04:12 PM
Black_G
May 3, 2016 12:28 AM
Igor911
Jun 13, 2008 01:29 AM
