Help Anyone removed radiatior fans?
Old Nov 23, 2020 | 07:31 AM
Abmhos's Avatar
Abmhos
Hey has anyone on here gone through removing the radiator fans on their g37? I cant find any DIY's on the topic anywhere and am having troubles getting it out. I need to remove the fans so i have enough clearance to get behind and remove/replace my auto belt tensioner.
Old Nov 23, 2020 | 11:30 AM
ChefMatt's Avatar
ChefMatt
I saw this, I am looking at replacing my alternator..might help
Old Nov 24, 2020 | 10:30 AM
BULL's Avatar
BULL
Moderador
The fan assembly comes out from the bottom of the car.
Remove the 2 10mm bolts in the top that hold the coolant reservoir
Remove the 2 10mm bolts that hold the fan assembly
Remove the Fan Module control electrical connector
Remove the undertray if you have one
Push up on the assembly to clear the assembly from the plastic guides at the bottom.
You'll have to tilt the assembly towards the passenger side of the car and it comes down from the bottom.
Pretty simple after you have done it a few times.
Infinibini
12
Oct 7, 2019 06:46 PM
TheDevilsG
18
Sep 14, 2019 09:27 PM
Yellafella
May 30, 2017 11:23 PM
fgxmfmq
May 21, 2013 11:53 AM
Steveo47
Nov 16, 2010 06:21 PM
