Broken Axles
Old Feb 6, 2020 | 07:30 PM
Slowg37Sedan's Avatar
Slowg37Sedan
Smile Broken Axles
So i have Truhartt Coilovers sitting in my garage waiting to be put on, I already had them on then had to take them off because they were broke my cv axles, how would I put them on without ruining my cv axles?
Old Feb 7, 2020 | 02:22 PM
Installing coilovers should not damage your axles. There’s more to this story. How did they break you CV axles?
Old Feb 8, 2020 | 07:45 AM
Slowg37Sedan
When i took it to the shop they said it was in shapes they werent suppose to be in because of the coilovers. I put new cv axles in and may try again i just dont know if its going to ruin the axles or maybe they were just bad at the time and needed to be replaced
Old Feb 8, 2020 | 08:50 AM
Surfnazi's Avatar
Surfnazi
Is your kit universal or for your car
Old Feb 8, 2020 | 09:02 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Is your G a X model? Meaning is it AWD or standard RWD?
I'm with BlackBetty on this one. There is more to the story as coilovers should have little to no effect on CV joints. Front CV's (on AWD models, maybe), but the rears should not be affected at all.
Please provide more info...
Old Feb 8, 2020 | 01:03 PM
Slowg37Sedan
for my car which is a X
Old Feb 8, 2020 | 01:05 PM
Slowg37Sedan
the car is AWD when i lowered it it seemed fine And nothing was the problem it was only once i took it to the shop they said it was All messed up
Old Feb 8, 2020 | 01:30 PM
Slowg37Sedan
Also they said that the axles were in a S or a Z shape
Old Feb 8, 2020 | 01:45 PM
ILM-NC G37S
Still unclear as to what the shop deems "all messed up" and what they allegedly repaired/replaced. What was the diagnosis: torn boot(s), clicking in turns, thunking noise over bumps...? CV joints themselves are pretty reliable- it is usually the rubber boots that fail- but external factors can cause failure.
Typically, lowering a car a few mm's here and there will not affect the driveline too much. However, if your car is "slammed" the change in driveline angle can create additional stress on the CV joints, the axle, and the hubs- all leading to potential, premature failure.
All depends on how low your car is set at this point. I have no clue what a "S" or "Z" shape refers to. What kind of shop is this?
Hopefully others can add to the topic.
Old Feb 8, 2020 | 01:56 PM
Slowg37Sedan
I lowered it from stock to below the tire line, I guess about 3 inches. We replaced the axles with cv boot because it was needed, torn boots. Missed a retaining clip and that was causing clunking and damage where it went into the driveshaft(?). Once at shop and on lift they showed me the angles is the axles. They were not straight in and the angle into the back of the wheel portion was bent, —/ vs —|, if that makes sense. Said it was only a matter time before I hit a bump and they broke due to that angle
Old Feb 8, 2020 | 02:12 PM
ILM-NC G37S
A 3" drop is too much, especially for a AWD car. Most folks drop these cars 1" or so. IIRC, anything over 2" is pushing the limits. If you want the car slammed like that you will need custom axles- at least for the front but likely all four corners. You either have to reconsider your drive height or research custom axle sets that will take into account the different driveline angle.
keoman5
Feb 10, 2020 10:39 PM
BBR318
Mar 16, 2019 07:14 PM
Ro_JaBoy
May 22, 2013 06:49 PM
C@ciQ
Mar 17, 2008 03:18 PM
